My cargo box
South Jordan, UT
My original plan was to construct a split cargo box that would allow me to install/remove either or both halves as needed (I may need my third row to haul kids and kids' friends someday). Considering all the labor I've put into the first half, I may just call it good as-is. I'm also thinking that having the floor of the entire cargo area raised may not be ideal for hauling coolers and other bulky camping gear. Not sure how or if I'll proceed from here.
My box is constructed of 5/8 inch particle board and 3/4 by 1 inch fir, held together with screws and lots of Liquid Nails.
The drawer slides on 30" 250 lb slides from Lee Valley:
www.leevalley.com/hardware/page.aspx?c=2&p=46578&cat=3,43614,43616&ap=1
The handles and tie-downs were ordered from Allegiscorp:
www.allegiscorp.com
**if anyone ends up ordering anything from Allegiscorp, let me know. I need a few more handles, and they're minimum order is $30 (which my handles won't meet).**
I painted the tie-downs with Plasticote spray-on rubber stuff to minimize rattling.
The carpet is strategically stapled and glued with carpet glue, and it does a great job of hiding my crude carpentry.
The drawer is lined with vinyl runner material cut to fit, glued, and stapled.
The wood, carpet, vinyl, hinges and barrel bolt all came from Lowe's Home Improvement.
I've lost track of the bill at this point, but a few hundred dollars would be close to my cost so far.
The box:
The barrel bolt is to make sure that the loaded drawer won't lay me out when I drop the tailgate on an incline.
What to do with the cavity that's created between the wheel well and the tailgate? I decided to keep it simple by boxing it in and leaving a square hole that allows this cavity to be used a quick place to huck little junk you can't figure out where to put (seen at the left edge of the box in the pictures above and below).
I've added a lifting hatch that allows me to access the drawer without dropping the tailgate:
With the tailgate up:
The drawer is lined inside and out with ribbed vinyl rubber that I've cut to fit. It should be durable, easy to clean, and relatively quiet.
The drawer slides nicely on the Lee Valley slides:
Rather than have a giant drawer that ran the full depth of the cargo area, I decided to add a separate compartment that could be accessed from the second row of seats (as well as from the cargo area):
*I haven't lined this compartment yet.
**The photo is taken with the second row seats flipped up.
Here are a few shots of the basic construction:
The box is secured to the third-row seat anchors by two u-bolts, as well as one M6 bolt screwed into one of the mounts for one of the rearmost factory tie-downs:
The top of the box sits just above the third-row mounting hardware attached to the top of the wheel wells. The platform is well-supported across it's entire area:
With the 3rd row seat in. Toddler added for scale:
Nothing too complicated to construct--even for a novice like me. The most challenging thing was getting the drawer, lid, and hinge tolerances just right to make everything snug but still have enough room to slide, lift, and close.
Hayes
Awesome, very well thought-out and executed! I like the separate compartments that can be accessed from the back seat.
Nice work! That's pimpin':grinpimp: I like your version of the drawer/hatch combo, looks like it will function very well.
Do you have it secured to the tie downs on the floor of the cargo bed?
I have also considering doing a drawer have the width of the back, but worried about leaning the truck to one side or the other with the constant weight of the drawer and equipment in it.
:cheers:
Nice write up. After the second battery thread we are going to do a storage solutions, you can post the photo there and provide the link to this thread.
Great Job. I have been debating on doing something for half as well.
Ken
Looks very good, the only thing I would add, is a way to secure the big lid. That way, in case of accident/roll over (god forbid) the items stored in the drawer won't become missiles. Also can you detail how you secure the drawer system to the cruiser?
Thanks.
I added a description and photo of how I secured the box to the floor.
My plan was to add another barrel bolt to the left side (looking in) of lift-hatch to keep it closed in the event of a rollover. With further thought, I'm questioning the effectiveness of a barrel bolt staying closed in a rollover. Not sure what I'll do.
Hayes
Hayes-Nice work. I think you were smart not to make it full width. Mine is the same and the fridge mounts next to it at floor level. It looks very strong and beefy.
very nice.I too like the idea of a half storage box.My question is;can the remaining seat still be used if needed.
Dave
Dave
That was one of my goals, but to be honest, I haven't actually checked to see if the right-side seat will actually fit with the box in there :) .
I'll (hopefully) put the seat in tonight and take some pictures.
Hayes
I suspect your carpentry skills go far beyond "crude". That thing is sweet!
Yeah, I think the finished product looks good too, but you have no idea how long it took me just to measure and cut the particle board. I did all the cutting with only a circular saw (no table saw) and all the cuts were made without the benefit of any kind of physical guide. Needless to say, there are very few perfectly straight lines in the box, but because I used the 3/4 by 1" strips to assemble the cut boards, everything went together well despite the wavy cuts.
The main difference between my skills and someone with actual carpentry skill:
The box could have been built in half the time.
Hayes
Great Cargo box!! Need to do that myself here one of these days...good sumer project!
That looks great ! Everytime I have an idea and starting planning , someone comes along with a great write up and even better design. Sweet.
Hayes,
That box is awesome. I started thinking about keeping one of my back seats as well, even going so far as to try to figure out if I could mount the seats securely enough to the box (with reinforcements) if I wanted to put 6 peeps in the truck.
What would you do differently if you were to do it again? Lessons learned are always great to pass along.
