My body has shifted right!!
Gladstone Qld
i was gettin my rig prepped for body work and a rear quarter cut last night and i noticed that both front and rear wheels on the left side of my 60 stick out further than on the right.
looks as though the whole body has slide sideways on the frame. is this possible? is it detrimental? could it contribute to cruiser lean? it leans about 1-2 inches lower on the right hand side.
edit: how hard is it to move the body sideways on the frame? could i just loosen the body mounts and give it a shove or will i need to get a jack?
If you lean it back over, does it appear to pull the wheels back in? I'm guessing if you fix the lean, it won't look like the wheels stick out further on the high side.
yes you can move the body over. loosen all the bdy mt bolts and get a couple friends and slide, be mindful of the bolts wires, hose etc. if the frame is good base your measurements off that not the tires. suspension lean can sckew the visual look. measure of the frame frome boths sides in the same points and that will tell you how much it needs to move if any.
