- Joined
- May 10, 2008
- Threads
- 127
- Messages
- 889
Truck is here. I can't say I am totally happy with Kolly Classic Imports of New Zealand. He lied about some things. Joe Egolf did OK with him, but I am less fortunate. I mean the guy outright lied.
I was promised no rust. Bull$h!t. The upper lip that surrounds the top is rusted, filled with Silicone caulk, and painted white. It has no intrinsic strength so I cannot use a rooftop carrier. The inside aspect is full of rust flakes and in some places holes. I am very pissed. I am not sure how to even begin to fix this. I mean it. I am really pissed. It is a BJ-44 so it is an extended top. There is no real USA alternate source. I am unsure what to do!
The top where it connects to the lower body behind the door was Bondoed together. WTG butthole. I will not be pulling the top in anticipation of problems there. There is also rust in the pillar there. I have real concerns about this top.
Lower body seems OK except for the rust in the front bib, (at least I think that is what they call it). It is the thing the bezel attaches to that also has a hing all the way at the bottom center. There is also a couple of areas just hit with bondo as if this was an abstract art painting by Jackson Pollack.
The radiator seems to shake. It seem held in place by 2 battery hold downs at an angle. Is this normal?
The guy promised me paint was good. Bullcrap. He had some guy go over the car fast and dirty. It is already bubbling in some areas.
Batteries are unmatched and dead, but this did come from NZ on a 2 month trip.
The knuckles are leaking and need rebuild. Big surprise! I had already ordered a kit in anticipation of this.
Rear left ambulance door handle does not function and does not hold the door closed. The swing out tire rack is being used to hold the door closed. Neither door clicks into or locks into the lower body so I think something is broken. If I lock the door, then open the tire carrier both doors can easily be pulled open. Not sure what to do about that or where to get the proper door mechanisms.
Are there any sources out there?
Car has lock lugs and no key. No biggy. Just need to break out a few throw away sockets and a BF hammer if a pipe wrench doesn't work first. Who forgets to send a lock lug key though!!???
I was told they tried to jump the truck at the pier but it was a no go. I was certain that they used a 12 and not a 24 volt jump. I was right! Both batteries have corroded leads (one is broken from over tightening) but 2 jumpers in series got her started easily even after I forgot to use the glow plugs! She idles well and stinks of Diesel. WVO and bio-D here I come!
I was going to get new tires, but wait! Tires are brand spanking new!!! They are 31 by 10.5 wide!!! I think I can live with that for a while.
No radio. Just the sound of stanky ass Diesel fuel polluting the environment. There seems to be a radio circuit though? At least the fuse box is labeled that way. So does that mean I can insert a stereo without a 24-12 Volt converter?
Ammeter is not functioning. Where or how do I replace?
Hazzards don't work. What do I do?
Does anyone make 24 Volt gauges for insertion into a dash? Any of a size and shape that will replace the ammeter?
I will need to post pics later today, but I need to get wifey and son #2 to the aquarium. Then I need to go to Motor Vehicle and get her registered, then inspected.
Best,
T
Best,
T
