My (Anti)Sway Bar Squeaks
Z.O.W.I.E. Headquarters
Well this weekend I replaced took my front sway bar off, cleaned all the crud off of it, replaced all the bushings, and put it back on. Now when turning the wheel, the bar/bushings squeak. Apparently I should have used some lube when reassembling. What should I have used?
Thanks!
I think I have it fixed now. I went out tonight after work and took the bushings out, sprayed them with some white lithium grease, and reinstalled everything. Did a little test and things seem quite again. After doing a search on the internet i found that most folks recommend white lithium grease for that application.
Be sparing, as it will pick up grit.
Doug
Yep that's my mud user. :)
I forgot to mention, Meredith really liked your license plate frame.
