Thought I would put this out there to see what you all thought. Was on vacation last week --- still recovering -- fried like a lobster -- just getting back to working on the Pig. Found a new windshield from Toyota -- need to order the rubber gasket from SOR yet. As you can see -- still needs work. I think the Pig is a beauty.
Got some "running" problems. Currently have a Weber 32/34 on it -- loaned from a friend. Burns rich as can be. Took off the vacuum line since it tended to advance it too far (plugged carb port). Set timing w/o vacuum advance right on the beebee -- Is that correct? I also tried my 72 FJ40 carb on it but it seems to fight the vacuum advance distributor. I also seem to have some exhaust leaks on cylinders 2345. Do I probaly have intake leaks too.
I guy on EBay had the same intake manifold up for sale and said it was perfect for higher performance -- I think it is to a 69 since it came with a 69 carb (March 69 through Sept 69) -- as can see -- I have a header too -- not sure if it is homemade or what. I took off the smog stuff and replaced with a 3/8 inch ball bearing and put the cap back on -- thought that was a pretty good temporay fix -- maybe permanent.
It came with the 69 carburetor - I rebuilt but could not get it running right so put on the Weber -- She has the vacuum advance distributor and no condensor --- hook up to the ignitor pack on the coil to reduce voltage and not fry the points -- according to SOR.
Compression in engine is good -- about 145 psi across the board.
It only had one fuel line hooked up since the 69 carb did not have a return. Could that be part of her problem with running so rich? The plugs fowl -- Even when I put the 72 carb on. Do I want to keep the header -- take a look at the studs -- what probalems am I going to have when I take these out -- what is the best method w/o snapping them off.
Interested in what you guys think --
See attached pics -- If I attached them correctely. How do you place them into the text?
75Pig
75Pig
