My '69 Land Cruiser had a stroke
Utah
Well, I have been reading this forum for quite a while on and off. Since a bit before I bought my Cruiser off of Ebay last April or so. I've been driving it nearly everyday to work due to the ice and snow we've had here in Northern Utah these past couple months.
I finally decided to get off my butt and start posting here. Figured my first post would be to show off the Cruiser a bit, ask if anyone knows of a shop specializing in Cruisers up here and to get opinions on what my first mods should be.
Well, the Cruiser must have known I was planning on doing some work to her. Today, I decided to drive her up to the Toyota dealership (they have a fully restored Land Cruiser there and I have seen them working on old FJ's there) to get some key blanks and price some OEM weatherstripping. The PO had her painted and Line-X'd but the shop that installed the 'all new' weather stipping used the cheapest stuff available. It doesn't fit all that well, especially with a gap I can push my finger through at the wind wing area.
Driving along, about 1/2 way there I start getting stopped at every light. Each time I start off in first gear it seems to be getting harder and harder to get it into first. A little grinding, etc. I am planning on pulling over as soon as the light I am at turns green. Well, my Land Cruiser seems to have suffered a stroke. When I put her in gear, if I can, the motor dies. I am assuming it's the clutch at this point, but we'll need to wait and see. Had her towed to the Dealership as I don't want to mess with troubleshooting this particular issue.
Well, here she is, taken right before I headed out this morning.
Thanks for looking. Describing it as a stroke seemed appropriate. She still starts up, I just can't get her to get up and move. :frown:
Hopefully it is something fairly simple. I didn't even bother to open the hood to check on anything. I simply don't have the time right now to troubleshoot/fix the issue. At this point I'd rather just be driving it! :steer: I spent almost 3 years on my Camaro banging my head against the wall. And of course, no car is ever really finished.
Hopefully this doesn't end up costing too much and I can get back to having fun with it.
Yeah, sounds like a failure somewhere in the clutch hydraulic system. The system's really simple: Master cylinder, tubing, slave cylinder. Even replacing the whole system is pretty easy.
Nice looking cruiser. Not sure the dealer would know what to do with that V8 though . . .
The weather is definitely a factor. I have a huge garage but it is full and in desperate need of spring cleaning (putting Christmas junk away properly, etc.). I *could* pull the cruiser in but then you wouldn't be able to do anything in the garage.
I got the Ron Paul sticker from ronpaulflash.com. They are sold out now, but are very neat. They are made from electro-luminescent material that lights up like a neon sign with each color controlled by the little microprocessor. Pretty eye catching with all the flashing patterns at night.
Not to hijack the thread, but although Ron Paul doesn't have a chance of getting the nomination, I still like his message and want it to be heard more.
Oh, almost forgot... While I generally avoid dealer mechanics like the plague, I have seen several old FJ40's there. They even have a mechanic that specializes in them, including SBC's shoehorned in.
I was reviewing the FSM last night and nothing in the system seems too bad. Depending on what they say they are going to charge me, vs. my time to do it, lost time driving it, towing it back to my house, I just may end up doing it myself.
Yep, it was the Clutch Master cylinder
The dealer is ordering the parts for me. I think I may have them do the install. When I add up tow cost, working outside in the snow (1 inch of fresh this morning), etc. I start to feel better about
paying someone else.
Plus, they are going to clean the undercarriage and fully inspect and lube all the suspension and steering components for me at no additional charge. Now I just need to find a reputable shop here in Utah County or Salt Lake County that would install a Painless wiring kit.
Mine did they same thing. On V8 conversions you need to check the adjustments on the slave they come loose and make it hard or impossible in my case to shift. Good Luck
If they are going to do the master cylinder you might want them to do the slave to. When I bought my 68 I rebuilt the master cylinder (Toyota sold rebuid kits year ago) because it was leaking. A couple of days later while four wheeling in Northern Arizona the slave cylinder blew out because the rebuit master was alot stronger, had to drive it back with no clutch and a three on the tree.
John
Same thing just happend to me. I am replacing my master and slave, hose and all.
I bought the master slave assemly from JT outfitters for $124.00 comes with a steel braided hose instead of the hard line and rubber hose combo.
Easy and simple fix!
Dude,
You can fix this yourself. And you can drive without a clutch...no need to tow your rig. What does your dealership charge per hour in their shop? You can buy some nice tools for that. Fixing your own clutch hydraulics is fun and easy. You can choose OEM new or rebuilt. You can even rebuild your own if you buy a hone...
X2 on rebuilding/replacing your slave if the master goes, and vice-versa.
Perhaps instead of looking for a good local shop, you could be looking for your closest LandCruiser club?
