Mark
Thanks for the PM inviting comment. As I have said before, if I’m going to comment, I prefer to do so publicly, so that others may benefit as well.
The accelerator pump linkage is on backwards, and it looks like the secondary counterweight is frozen. I can easily add a vacuum advance port during a rebuild as well. Jetting is almost never the issue that people seem to make it out to be. The carburetor is more often the victim than the culprit.
Also keep in mind a mechanical secondary (what you have) will never let you down the way a 2F vacuum secondary can. But it is also true that a properly rebuilt and tuned carb trumps all.
Yes we did finally get it started. All that was needed was a slight adjustment to the Dizzy allowing the engine to be in proper timing and it fired right up. So now we can move forward. My buddy Bill aka @POPO AGIE has the 4 spd transmission and transfer case done so hopefully soon we will have this along w the new Birfields to build the four wheel disc brake system. The carburetor from @SlapSmak worked perfect.Did you ever get this 40 going?
But this rig is a 1971 truck with a 1978 engine. Did they have emission crap in 1971? Or maybe the PO swapped over the parts off his 78, which he wrecked. That vacuum switch does look original to this vehicle tho.
And you tried to convince us that you didn’t know what you were doing !All that was needed was a slight adjustment to the Dizzy allowing the engine to be in proper timing and it fired right up.
