Multi fuel military diesel
Oriental, NC
Check with Roger and Rob. They are members of the STLCA (TLCA chapter in TN). They each drive a 40 and a 60 that have been converted to the military surplus V8s.
Yes and yes. Not sure that the military ever actually called the 6.2 a 'multifuel" engine. But it will run on most anything. :)
Mark...
The civilian version of these motors will also run on other fuels, as long as you stay with the mechanical injection pump. The mechanical IP was used up until 1993 on the 6.2 and 6.5.
1994 was the start of the electronically controlled IP. The optical sensor used with this IP won't work properly with anything other than diesel fuel. The good thing is that any newer 6.5 motor can be retrofitted with the mechanical IP.
The mid to late 90s era motors built by GM have a reputation of poor quality with the block casting and machining while the early 90s 6.2 and 6.5 have a much better reputation.
However, in about 2000 Navistar took over from GM in casting and building these motors. Navistar changed the metallurgy and revamped the castings to get a a much better and stronger block.
It is possible now to get military takeout motors with Navistar cast blocks. I've read of a number of people who got these mil takeouts who pulled the heads to check them and change from the TTY head bolts to ARP studs. All that I have read about, except for one, have reported that the valvetrains, heads, and cylinders looked like fresh rebuilds.
To make a long story short, there are mil takeout 6.5s also now available. Almost everything will interchange between the 6.2 and 6.5, older or newer, military or civilian. It is possible to put the 12V mechanical IP on any of these motors and use other fuels.
Don
Yup there is a guy running around me with one installed, w/matching tranny I believe. If I were to take a guess Torfab up here by me did it. But thats only a guess. My brother runs that engine, I got him running un heated hydraulic oil and waste plant oil. I am on him every time to get a fphe in it but so far so good.
Handcannon,
This is great news. You would think this would get a lot of folks moving to these conversions.
What do you see as the downside, if any?
Handcannon,
the mileage on other diesels should be a bit better. But for a cruiser I believe they share the same bolt pattern as a SBC so they can use an off the shelf adaptor, with less fabrication then some other swaps.
Old school mech injection pumps like the ones in the 6.2 and early 6.5 will allow you to use all of those in varying mixtures. Especially for short term situations (this is what the military "multi-fuel" designation refers to ability to run just about anything when you have to).
Mark...
Handcannon,
I have no experience with any alternative fuels so I can't really give you a definitive answer. I'm new enough to diesels that I'm still learning about them.
My first diesel was a 6.2 pickup that I bought primarily for the bed for making a trailer. I drove it for a while and liked it so well that it is my motorized trailer just for use on the property.
I then had a chance to get a real cheap 94 Chev K2500 6.5 TD that needed some front end sheet metal. Because of these two pickups I'm sold on how easy and inexpensive (compared to other diesel motors) these GM diesels are to work on. In the past three years I've had time to do a lot of reading and learning about these diesel motors.
If I had the funds I'd be getting one of these mil take take out AMG (Navistar casting) 6.5s and replacing the tired high mileage 6.5 TD motor currently in my pickup.
http://teds-trucks-and-stuff.com/ab...e&search=Diesel, Gas, Lifts, Trailers&logic=1
I'd replace the TTY head bolts with ARP studs, maybe use thicker head gasket to slightly reduce the compression ratio, and replace the GM4 turbo with something that is better suited to towing.
I've been slowly collecting parts to put a 6.2 into my FJ40. It will have a mechanical injection pump (for simplicity) to allow me a lot more leeway on fuels than my electronically controlled IP in my 94 pickup.
Don
