I am leaving on a trip tomorrow.
But I'll be driving into town early tomorrow to get my medical, and to stop by CDan (and Onur one way or another--you left your allen wrenches in the shop)
FWIW, the HJ-60 (has a 2H in it) uses a different filter than my HJ-45 (which has an H).
I also checked, and the 2LT-E uses a different filter too. VERY similar, but slightly different. So no luck there.
Not sure if it would work, or would be worth it, but you guys are more than welcome to snag parts off of my HJ-45 if they will work for you. The oil filter adapter from an H *might* bolt onto a 2H to get you home. I'll be heading out tomorrow, but my parents could certainly let you up to the truck to get parts off of it if it would help. I also *might* be back home on the evening of the 23rd. If you need: ring me up at 366-8662.
Dan (CruiserDan, not me
): you can't check Toyota Industrial parts can you? The H was sold in North America in forklifts.
After Toyota, I'd check with NAPA. I've had good luck getting the 1368 filter from them (which crosses to the also difficult-to-obtain filter for my 2LT-E). One time when I called they had 3 in stock in the main Albuquerque store. You'd be surprised what sort of ag equipment uses the same filters.
Are you shutting it off, or is the EDIC relay commanding the shutdown? Is it possible that the sending unit is bad? It sure does sound like a clogged filter, or a clog/loose junk near the pressure sending unit(s).
Dan
