For Sale [MS] FJ60 DC Driveshaft Joints
MS
I have a two front DC joints from a pre-84 FJ60. I have cut the shafts off leaving the joint ready for a new tube and slip joint to be welded on. I can include the slip joint and remaining tube if desired.
The cleaner joint supposedly had Spicer u-joints installed about 5 years ago, but has not been run since. The other is probably still original. There is a lot if dirt and grease build-up on it.
$60 for the cleaner joint and $50 for the dirty joint. I will include the slip joint and old tube for an extra $10 each.
The short tube and slip joint is 27" as is and the other is 30" as is.
These are located in Ocean Springs, MS 39564
