MPG Sucks, Exhaust Leak: Rebuild?
Kennett Square, PA
Website
cruisin4parts.com
Lately, I've been noticing terrible mileage. Also, I've heard a different noise from the engine, the exhaust line from the engine to the cats. There's a leak right before the cats it looks like... The engine runs pretty rich I guess, burning the gas and my wallet!
So, I'm thinking that I might as well replace the whole damn system since the muffler is hitting the driveshaft, the tailpipe is held up by the frame and now a leak.
I'm going to go searching for a good place that will do my system and for a reasonable price.
My questions are:
What should be a reasonable price for replacing my exhaust system?
How should I replace it? I've read people "gutting" the cats..
Which muffler should I get, I've been running stock this whole time.
I really don't have a lot of money to spend, so I'd like it to work, yet slightly upgrade it. Working and possibly working better.
-Edit- Could the bad MPG be because of something else?
I had a guy near me that was gunna replace the cats and new piping from the cats back and a flowmaster muffler for 330 bucks but that was a HELL of a lot cheaper than I though it was gunna be ....
it was some down home country boy shop up here in the mnts of NC where I live
Crappy gas mileage can be attributed to a number of things... A basic tune-up can help a lot. How's your fuel filter? Air filter?
As for the exhaust leak, it really depends what you want to do with the system. Do you want a more aggressive sound? (slightly) more power? or just want to get rid of the leak? Many shops can weld a leak for a small price... I forget how much.
I've been planning to upgrade my system to a single 2-1/2" catback w/Flowmaster. It lets the motor breath better. I also have a leak somewhere....and a few mounts are busted...
In your case, being in NY, winter blended fuels and the contribution of ethanol (E10) could easily be cutting your mileage 15 percent compared to summer mpgs.
I do not know if gutting your cats are going to get you thru NY inspection either. I installed a system at my local custom exhaust shop from the cats back, duals, flowmaster bent in the original routing position for 340$ a few years back. Best mod I have done. If you are adding non oem (hiflow) cats it will be a little bit more for those and to fix the leaks.
How bad is your mpgs? Mine is 13-13.5 now w/ winter fuel and E10 but I am well tuned. Will squeeze out another 1 - 1.5 mpgs in summer using summer blended fuels.
What exactly do you mean by "well tuned" Sorry for the thread hijack, just trying to get a few mpg's out of my 92. I recently replaced the air filter. How do you know when to change a fuel filter?
If it hasn't been changed out for a while, then it should be changed. That's how I am.
On a 92, it's not that hard... But a pit or a hydraulic lift really helps out.
I put a Borla cat back in my truck for about $400, and I put in two of the Magnaflow cats (only needed one to do the job of the two factory cats....Doh! I think they were $120 each). I will be honest, it's a good exhaust system and the price was right, but on the highway it drones pretty loud. The sound never bothered my that much until I recently took my truck on a 1800 mile trip and the constant droning really sucked! At times I wondered if that was what WWII pilots had to put with, but I imagine Corsairs and Mustangs were a tad louder. Anyhoo, if you don't do a bunch of cross country driving (like who the hell would drive FZJ80 cross country these days with gas prices that way they are????) I think the Borla, Flowmaster etc will make you happy. You can install it yourself in an hour, and it's not a bad price. I had to make new hangers for mine because it was a rust belt truck. That was easy, and with the exception of the above noted noise, I like the system.
For starters, properly maintaining your ignition systems (plugs, wires, cap, timing), intake and fuel system (clean filters, clean fuel system & calibrated injectors, new O2 sensors), having the rig properly baselined with fresh fluids & greases (my preference is synthetic) in the engine, diffs/tranfer case, tranny and driveline, and a properly operating emmisions/egr/vsv system and cooling system.
