Goal: Have access to a library of movies and video games playable on all 3 screens in a 2016 Land Cruiser with no internet required. Remote controls for the video menu as well as the gaming menu will be XBOX 360 controllers. It must require only minimal computer experience and be easily repeatable. Preferably have an already documented process.
Prerequisites/Assumptions: I went into this with hardware installed from my Beatsonic Smartphone Mirroring Kit post, which gave me a HDMI input and a USB power source inside my glove box. This is only required to get this working on your front dash video screen. If you don't care about having that in the front and only want this accessible on the screens in the backseat, it's unnecessary. There is a HDMI input and a power source in the backseat, but that will only provide video for the back seat. You cannot use the rear A/V ports for viewing on the front screen.
Hardware required to follow my path exactly (you can modify this at your will, it doesn't require exactly what I used):
Software/Guides:
The skinny: I spent a considerable amount of time trying out various builds, images, and software. Most methods worked well for 90%, but failed miserably in the other 10%. I landed on using OSMC (Open Source Media Center) which is in its most basic terms an operating system designed for running KODI, a media center software. I won't muddy the waters by going into much detail, but it's a very easy install.
For the most part, follow the instructions using the install guide I linked to get going, but please read my notes below completely before you get started to save some headaches:
Main Menu
Movie
Game
- Beatsonic Smartphone Mirroring Kit
- XBOX 360 controllers
- XBOX 360 wireless battery pack and charger, I use the Nyko Charging Packs/Station (can fit in the back door pockets when not in use)
- You can use the AC plug in the rear of the vehicle to run your controller charger, or buy a DC to AC inverter, I use a Stanley Fatmax Inverter (can fit in the back door pockets when not in use)
- XBOX 360 USB wireless receiver
- Raspberry Pi 2 (I would recommend using a Pi 3 at this point, I just had 2's on hand)
- Wireless USB receiver (not required, I used a small cheap one from canakits)
- You will need a microSD card for the OSMC OS
- You can either use a very large microSD card for the OSMC OS or add a USB memory card to store your movies/game rom's (I recommend using a large microSD card to keep the power draw as low as possible)
Software/Guides:
- The below guide is for installing OSMC and then Retropie on top of that OS. This is an easy process, but it's already written so why not use that instead of writing it again:
- My suggestion if you're unfamiliar with these: Use Putty for SSH and WinSCP for transferring files (movies, roms, etc.)
- Before you ever connect it to the land cruiser HDMI, you'll need to add "hdmi_safe=1" to the "config.txt" file in the /boot/ partition. If you're running Windows, you can connect the microSD card to your Windows computer and what you'll see as the drive is actually the /boot/ partition, so look for the "config.txt" file, add the text at the end of the line in there (don't add a new line or hit enter), save it, safely disconnect the card, and you're good to go. Without this text, all I ever saw in the Land Cruiser was a blue "No Input" screen.
- When you first boot up the image, you should see the OSMC logo and it will do some housekeeping tasks like expand the image to fit your microSD card size. Following that, it will reboot, sit at a black screen with some text for a couple minutes, then it will boot into OSMC and start up the configuration tool for you so you can configure some important details that will help you later on
- Do this entire process at a larger hdmi screen with better resolution, do not do this in your land cruiser unless you are very familiar with the questions it's asking. It's hard to read and picking a wrong choice here can make it not work right or not work at all.
- If you ever need to modify any of these settings or even just your network settings, go to the add-on's section inside OSMC, look for "My OSMC" and choose to run that, it will run through the same settings.
- I did not have to do any configuration for the XBOX adapter and controllers to work. I plugged the adapter in, turned on the controller, synced the controller to the adapter, and OSMC immediately recognized it and I could browse the menu.
- If you're unfamiliar with using SSH, Putty, and/or WinSCP, try a couple youtube videos to figure it out, the barebones capability of each are not hard to figure out and that's all you need here.
- When you run the retropie installer script, it will take a long time to complete (1 hour + for me on the Pi 2). Pi processing power is relatively low, so installers take a while.
- I know that the Pi 2 can run Playstation and N64 emulators okay, I just haven't found the right emulators or settings for those. Lower emulators work fine.
Main Menu
Movie
Game
