Mounting winch in ARB
Seabeck, WA
Well, I have been playing around getting the winch mounted in the ARB prior to installing the whole set-up. The directions are pretty vague, but I have things so they look good. I am just wondering if there is a "required" orientation for the winch "control box"? As you see in this pic it is vertical, which seems like a good way to go, easy to access the remote plug, unless someone tells me a reason it needs to go horizontal?
Just looking for some experienced input here...
Also, this was another part included in the ARB mounting kit. Can someone tell me what this is supposed to be for? Another means of mounting the winch control box?
Thanks in advance!
Rich
on a tangent, is the fairlead opening size and mounting system some sort of standard that Warn and others fit?
That bit is for mounting the control box elsewhere.
If the control box is not close to the bar that is just in front, you will hit your grill. Did you have a black bracket to mount the box to the allen head screw that hold one of the chrome rods?
How much in the way of spacers did you use for the motor not to hit the bumper? The golden bracket is to mount the box to the motor with some hose clamp that may of been in the bag with the other hardware.
I mounted the XD9500 recently in my ARB and had to use 1 inch spacer to allow the motor not to hit the sloping part of the bumper. I like the winch so far.
As for the fairlead, yes it is prettly much standard pattern, but to fit it into most ARB's you will need to drill the fairlead so the bolt hole is lower so the fairlead will bolt on to the bumper with the supplies bolts by ARB.
As for the licence plate bracket, if you plan on mouting a USA plate you will need to bend the bracket up some to allow the plate to fit. later robbie
Cantt tell from the photoangle but you might be a bit far back on mounting the box. I fabed a bracket that attached to the light mounts and it put the box pretty much directly over the top of the winch with about 1.5" of clearance from the front of the grill.
