Motor mounts
Discussion in '60-Series Wagons' started by BigSur, Jun 22, 2005.
  1. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Would a lose motor mount cause roughness? Not idle roughness but roughness in general?
  2. BMAN
    BMAN
    3,281
    Media:
    6
    Albums:
    1
    9
    May 13, 2002
    Greg's place
    Yes, and so will herpes.
  3. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    no.
  4. 3pits
    3pits
    2,226
    25
    Jan 14, 2005
    NE GA
    possibly, but it is more likely only to exagerate/make you notice roughness from the engine
    I have seen 2fs with 3 broken MM look fine except they twist like a raver on x at a disco party,, when you rev them up,, the broken MM allowed the motor to bounce in stead of gently sway within the confines just my .02
  5. BMAN
    BMAN
    3,281
    Media:
    6
    Albums:
    1
    9
    May 13, 2002
    Greg's place
    I had a bad AA mount on the 40 that once it was fixed smoothed out the ride a bunch. Iwas actually amazed at the difference it made. It was so much quieter on the road and trail. I felt like I had a new rig.
    EDIT***
    Is the mount LOOSE or BAD?
  6. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,345
    1,369
    Apr 4, 2003
    Panamá
    always I was noticed about bad ( but present ) MM with the fan grinding in the cover .. ( fan cover off course )
  7. Cruisergreg
    Cruisergreg
    1,846
    3
    Jul 20, 2003
    FJ60 MMs are kinda weird in that they don't have a "through" bolt like most. In other words, only rubber is connecting the motor to the frame. These can fail gradually as a crack in the rubber gets bigger and bigger. If one was beginning to crack you could get the engine jumping around a bit which might make it feel "rough".
  8. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    7
    Feb 5, 2005
    this is what mine does, fan grinds the shroud. usually only when i get on it or in 4wd.
  9. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Well it turned out to be a bad motor mount...the bolt underneath was loose as a goose and that was causing a vibration. The bolt is now tightened and she purr's like a kitten again.
  10. Tapage
    23,345
    1,369
    Apr 4, 2003
    Panamá
    off course in 4L is the moment when your engine push more torque and power on the diff .. and the left side of your engine ( driver side ) raise ..
