Motor mounts
Lakehouse
Anyone used the CCOT motor mount kit shown in this link? ---http://us.st12.yimg.com/us.st.yimg.com/I/coolfj40_2047_13922323
SOR has the square fronts and the round rears also. CCOT "kit" is about 20 dollars cheaper than SOR parts.
What other options do y'all suggest? I am not opposed to using old mounts, but by searching I understand the fronts should definitely be replaced but the rears are not as critical?
This is for a 75 2F engine
While they'll cost more I've found OEM Toyota parts typically work much better than the after market reproduction parts.
This is usually my preferred route, but....
SOR states round type OEM no longer available? I did not check with Cdan on this one though.
Also, a post in the search function mentioned that the aftermarket square type front mounts are superior in strength.
