Motor Mounts?
Calgary, Alberta
Hey my HJ60 Has some vibration when it idles... Now I know diesels rumble a bit but is warn out motor mounts a common problemo, or is the shake normal. (When I idle it up a bit to like 750rpms it tightens up a bit) but at 500-700 rpms she shakes.
Thank you
Andrew
Thank you
Andrew
Ya...........best price I found was Spector
Thank you
Andrew
BOth of mine vibrate at 500-600 rpm and rattles all of the contents of the vehicle. It returns to 'normal' at 650rpm when warmed up.
x2 My friend had a ex outback HJ45 years ago and when idling low it was like being in an earthquake but as soon as you raised the rpm 100 or so ,it was ok.
standard diesel shake. Idle it up a little. My Merc does it, my Bj does it, my TDI golf did it.... anything else I have been in does it too.
If you want when it is warm turn the idle up till it just gets a bit smoother. 500 is too low for an idle anyhow,
