Motor fan cowell
Dominical Costa Rica
I have instal an electric fan in my cooling system Betst to blow out against radiator or better to pull across radiator to motor B series 4 cylinder? Also, will a cowell for the fan be needed?
Thanks.
ceylonfj40nut
Waiting for Barn Time
TX
Are you using both mechanical and electric fans??? Not sure about Costa Rica, but here in Texas, the electric fan you show does not work. I swapped it for a Volvo fan which is much better than what you show. Still did not work. My suggestion to you is build a shroud to work with your mechanical fan. That is the best and only thing that works!!
Mechanical fan will still be installed. Thanks for your information.
