I found a super cheap carburetor for $78 on amazon that says it is compatible with a 2F 4.2L 1969-1987. My gut tells me this is way to good to be true but the reviews so far on Amazon (all 6 of them lol) are fairly positive.
Here is the link to the carburetor ... Amazon product ASIN B089Y7GWND
1) Is it any good?
2) Will it work with a 10/1985 FJ60?
3) What modifications can I expect to make? It sounds like I will use my original idle solenoid power connector. Will the existing heat riser that I have work? Is there anything else I should consider when trying to attach this to the trucks original intake manifold and heat riser? Aside from getting new gaskets. Will my existing choke system work?
4) I will be traveling to areas with higher altitudes and colder climates. Should I use high altitude jets? Turn down the idle mixture a bit?
5) Is the idle mixture screw on this carb in the same spot as the original OEM carb (side closest to the air cleaner?
6) Is this the same carb mentioned in the So I tried this cheap ass carb... - https://forum.ih8mud.com/threads/so-i-tried-this-cheap-ass-carb.1051191/ post for Fj40s?
Here are some pictures. Thanks for your help!
1) Is it any good?
