RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Anyone wired these up yet? Im looking to see how or IF the tweeter can be integrated So it isnt in the way.
Yeah. Love mine. Not totally sure I understand your question though. Surface mounted the tweeters. Only took a small hole in door for the speaker wire.
[/QUO
THE PIC ANSWERS MY QUESTION, THANKS
what did you mount in back doors? Im trying to find morels that would work.Yeah. Love mine. Not totally sure I understand your question though. Surface mounted the tweeters. Only took a small hole in door for the speaker wire.
Another mud member gave me the fronts, thse arent something I would buy. BUT now that I have them Im going to install. I have blown out 3 sets of polk speakers so far. No on the sub, I dont go that route anymore.In the front you will want a separate set in the rear either their 5.25" or 6.5" coax will be just fine.
You really should approach this just like any project and put it together as a whole not just piece things together. What is your end goal? Do you want a single multi-channel amp or amps for highs and lows? Are you going to have a sub? etc.
Did you time delay each channel to suit the driver?Ditch rear speakers, front stage setups are better imo. I went with a fully active setup 3-way(1 amp channel per speaker; tweeter, midrange, woofer) I mounted tweeters on the a-pillar and midrange replaced the dash speakers.
My manYup, dsp tuned with time alignment for driver.
