morganism
SunkCostFallacy
I've read thru the "Blinker no Blinky, and the other two headlight switch threads here:
High Beam Lights FIXED!! Finally!
and
Help - electrical issue.
Got power to headlights and lamps with key off, wipers with key on, hazard lights working, replaced blinker relay, and popped the cover , cleaned contacts on the two switch boards in the switch itself.
Was a full stop on turn signals, from working perfect, to no signals at all. Swapped out the relay module, checked the harness from the steering column, and checked fuse, tho i may have missed a relay if they route thru another one. All other dash lights still working.
No relay "click" response on either new or old relays.
Suggestions ?
and
Suggestions ?
