More rattle on startup
Discussion in '80-Series Tech' started by snowwolfwarrior, Jul 3, 2005.
  1. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    I have noticed that my engine is far more rattly on startup, I did change the oil a few weeks ago to castrol magnatec 10 40 I did not change the filter as I do that every other oil change, it rattles only for a few seconds on a cold start up, but it is quite loud now.
    I have read on forum about the rattle and some cures and fixes, but has anyone recently found any new ideas on how to stop it.
  2. 92FJ
    92FJ
    111
    Nov 23, 2004
    FL/NY
    Some people say to use a smaller oil filter and others just dont mind. I have start up rattle from time to time but its totally normal most mechs say.
  3. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    mmmm I have read that the ratle is nothing to worry about, but being an engineer, I just need to know what the noise is, its the not knowing that worries me.
  4. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    It is related to the timing chain. Robbie has had luck reducing/eliminating it by enlarging the oil hole to the chain tensioner. This lets the tensioner get control of the chain quicker.
    I have a very unsubstantiated theory that rare broken chain slipper is related to start up rattle.
    https://forum.ih8mud.com/showpost.php?p=564016&postcount=17
    Things you can do to reduce or eliminate it is get you start up RPM down by cleaning the throttle body and or O-ring trick on the idle air control valve, and as you said use the smaller filter. If that does not do it look up Robbies posts about the oil hole.
    Or just let it rattle.
  5. Dusty
    Dusty
    2,595
    45
    Oct 7, 2004
    I put a preluber on mind and rattle almost gone but if i turn off the luber (i have a switch) the rattle is back. These observations are consistent with the chain tensioner concept-give tensioner oil (preluber or drill it out-as in prior posts) and rattle can be minimized.
  6. Tools R Us
    Tools R Us
    23,767
    5,501
    Jul 20, 2004
    Chandler, AZ
    I changed the Rotella T 5W-40 and big Purolator Pure One filter to Mobil 15W-50 and new "cheap" OEM filter and the rattle went away, '96 with 49K miles. My brother just put Rotella T 5W-40 and a small Purolator Pure One filter in his truck and no rattle, '97 with 110K miles. Maybe the big filters have something to do with making it worse?
  7. tacomafj-80
    tacomafj-80
    171
    Mar 29, 2005
    el paso
    I use Mobil 1 10-30 syn. with a fram 3600 oil filter and I dont have any rattles at all. It may be the t-chain tens. as others have stated. I had the same problem when I had a toyota truck with a 22r. It turned out to be a busted timing chain guide. on a side note-I like running the bigger filter. any opinions on whats the best filter out there?
  8. tacomafj-80
    tacomafj-80
    171
    Mar 29, 2005
    el paso
    Thanks Kevin-good info :beer:
