More Brake Stuff
Discussion in '40- & 55-Series Tech' started by Eternal, Mar 2, 2004.
  1. Eternal
    Eternal
    247
    Jan 3, 2003
    So just a quick update first the 70 40 mass overhaul conversion has been put on hold as I have purchased a 73 40. Now I need to get the 70 40 running as is and so I have stripped out the master and wheel cylinders(8 of them) and took the wheel cylinders in to "brake guy" to see if they needed to be honed out. They are all in pretty good condition except that I have 3 rear with 1 mismatched and 3 front and 1 mismatched and it turns out that the singles that I have are the ones for the 70 40 the other 6 belong to another year. "Brake guy" is addiment that I not set up with mismatched sized as "it's an accident waiting to happen" even though it has run that way for 12 years(yes I did have 1 wheel lock up on me a couple times in just regular braking situations) I don't want to replace 6 wheel cylinders and the 6 are significantly smaller than what the correct ones are (about 1/8" smaller bore)
    Question: "Is "brake guy" over reacting to the situation or can I just get a matching cylinder to the sets of 3 I have and run with that?" This was my plan but just wanted some confirmation or correction before I proceeded. thanks
  2. Eternal
    Eternal
    247
    Jan 3, 2003
    Anyone?
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    "Question: "Is "brake guy" over reacting to the situation or can I just get a matching cylinder to the sets of 3 I have and run with that?" This was my plan but just wanted some confirmation or correction before I proceeded. thanks "
    Get the new ones so everything is the same, and run em...
    Good luck!
    -Steve
  4. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    I totally agree. Just get new ones. Why futz with brakes?
  5. 72FJ40
    72FJ40
    130
    Apr 7, 2003
