For a while now the moonroof will not open, not sliding or tilting.
I also had water coming in the footwell during heavy rain.
Somewhere on FB I read to remove the glasspanel and then clean the holes.
So I did that today and tested it with some water.
The drivers side was fine, but not the passanger side. There was no water under the ar.
Armed with a piece of cable tie I poked in the slits and water was gushing out. Found the problem.
While to glass panel was off, I checked the mechanism.
When trying to tilt the roof, one side the cable is moving and lifting a little, the other side it is not moving at all.
Does this mean the cable is stuck/broken?
It doesn't want to slide at all.
