Mobile 1 Synthetic Grease for Packing the Wheel Bearings and the Knuckle
Ok for the bearings. Use moly fortified for the birf/knuckles...unless you are talking about the knuckle bearings...Mobil 1 is fine there, too.
I used the moly fortified on the knuckle bearings in the last job I did. Those are slow speed bearings and they sit among all the moly grease in the knuckle anyway...so it seemed natural to pack them in the moly grease.
Did the same with mine, using the same reasoning.
Eric,
FYI, I spoke with a Mobil 1 engineer about this and he explained that they oversaturate the grease with oil - well above what competitors do. As a result, there is more of what we know as 'separation'. It's no excuse - just wanted you to know. I also agree it's annoying as my hand gun makes a freakin mess.
DougM
IdahoDoug said:
Eric,
DougM
I don't understand the statement from Mobil. Grease is basically oil with a soap based thickener added (lithium, aluminum whatever). So saying it is "oversaturated" (probably not a correct term to use) with oil is the same as saying it is light on thickener.
Why would they do that? Makes no sense to me...
This is interesting stuff ... I've always loved Mobil grease and used it exclusively everywhere I could but the separation problem always annoyed me; it separates out of my grease gun at an annoyingly rapid messy rate, it separated all the time out of my 4Runner hubs, it separates super fast out of my driveshafts which I actually sorta like cause its like 'flushing' the joints and splines with grease. Guess I'm sorta glad my experience with it was common. I always associate separation like that with low quality greases for some of the reasons mentioned already and normally would make a mental note to never use such and such brand if someone showed me grease that was separating. Yet I continue to use the stuff simply for brand loyalty or brand love if I'm honest about it.
So what's the word on this??? Why do Mobil and reportedly also Amsoil separate so much and is it good or bad or indifferent? Also is there any Mobil Moly Based Grease available or not? I've never found any.
There's not a problem with the M1 grease, or a shorted amount of thickener. It meets/exceeds all specs for this type of grease AFTER it oozes out the oil. The oil is what actually lubes, the thickener just holds it in place. As a premium product, Mobil knows that the more oil they can get into the mix, the more oil as a percent will be in the space the grease is placed. That's how it was explained to me. They have to meet a minimum density/weight/performance standard for various SAE specification. They do that and more with the extra oil that does tend to separate out when sitting. I suspect Amsoil would say much the same but have never asked. I did once complain to them about separation but honestly cannot remember what they said. What I DO remember is that they sent me 4 new tubs of grease without even being asked. I thought that was pretty indicative of their whole approach to product performance and customer satisfaction.
DougM
I've been toying with the idea of going with some other possible greases the next time around with the knuckle service (early spring).
Here's some that I've been thinking about:
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=2655&PMITEM=01242692
I'm wondering if Mobil's other high-performance/heavy load/high friction greases might be better for specific applications (wheel bearings/trunion bearings/drive shafts).
I recall as well that RavenTai talked about some AeroShell grease products that were even better than the Mobil ones...IIRC.
In any event, I'm going to be buying a bulk supply next time. No more of this running to Autozone at 8:55pm to get a cartridge of grease...
Cheers.
-onur
Akron, OH
