Mobil One Grease
Discussion in '80-Series Tech' started by 410225, Mar 10, 2004.
  1. 410225
    410225
    230
    Sep 2, 2003
    I just purchased Mobil 1 grease (Blue cap w/red grease). Can I apply this to drive shafts and u-joints? Do I grease it until the oil crappy grease comes out?
  2. sjcruiser
    sjcruiser
    834
    3
    Apr 3, 2003
    That's what I use for the chasis (except for the steering knuckles which requires MP grease). Apply few squirts into the u-joints & pumping into each driveshafts till it starts to move.
    Frank.
  3. 410225
    410225
    230
    Sep 2, 2003
    Thanks Frank. WHat is MP grease?
  4. turbocruiser
    turbocruiser SILVER Star
    3,562
    27
    Dec 24, 2003
    Okay, so let's say I have 'a friend' who added Mobil 1 grease to the plug that the knuckle has on it. What would 'this friend' want to know about this mistake...is it really harmful to have non MP grease in there, should I, I mean 'my friend' redo the knuckles now on my, ahh, I mean 'my friends' truck? :-[ Thanks.
  5. Greddy0
    Greddy0
    53
    Nov 14, 2003
    My 'friend' did the same thing :-[ Anyone ??? Problems ???
  6. hpantier
    hpantier
    113
    Feb 4, 2004
    you guys need to get some new friends....
  7. Pitbull
    Pitbull
    682
    3
    Oct 31, 2003
    I've used synthetic grease in my knuckles for over 100K miles and no problem.
  8. ppc
    ppc M Go Blue
    2,015
    578
    Aug 18, 2003
    Nashville, TN
    The biggest problem with mixing greases is that the combination may cause the entire mess to liquefy and no longer lubricate like it should. That's true in knuckles, u-joints, slip yokes etc. In the case of the birfield mixing with the gear oil is also a problem. The spec requires a moly fortified grease. If a non-moly grease good quality (M1), is in good condition and not mixed then you are getting protection but not as good as what a good moly grease would provide. Would I panic and change it out tomorrow? No if looks to be in good condition. If it looks thin and oily yes. Would I use M1 in a birfield during a repack? No considering its cost and that it is not the best application.
  9. turbocruiser
    3,562
    27
    Dec 24, 2003
    [quote author=Pitbull link=board=2;threadid=12884;start=msg118780#msg118780 date=1078957196]
    [/quote]
    Just so I read right, you are using the synthetic grease throughout the knuckle right? In other words, you are not doing what I did and mixing the greases right?
  10. Pitbull
    Pitbull
    682
    3
    Oct 31, 2003
    I'm using the synthetic (6 squirts at a time in the knuckles every 3-5K miles) have for the last 100K miles. I've never done the birfields but I only have 135K+ miles on them so I figured I'd wait until they were broken in at 1/4 of a million miles. I use synthetic in the diff's and tranmission and transfer case. I'm doing a research paper on how many miles you can go before you have to repack the birfields (I'm waiting for seal or birfield failure as the time for repack) I know it will cost me $500 per birfield if I damage them. Hey I'm doing this for you guys :)
  11. Beowulf
    Beowulf
    12,529
    55
    Mar 27, 2003
    Somewhere in the foothills...
    Also known as throwing one's self on the stake. :)
    -B-
  12. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Hey, FWIW, not all synthetic greases are the same. The M1 as mentioned is not moly fortified. The Valvoline MultiSnyn is a moly fortified full synthetic that can be used throughout the axle.
    Tom
  13. Pitbull
    Pitbull
    682
    3
    Oct 31, 2003
    Mine is the Valvoline synthetic :) Guess I got luck and picked the right one by accident. Sometimes it's better to be lucky than smart.
  14. turbocruiser
    3,562
    27
    Dec 24, 2003
    [quote author=Pitbull link=board=2;threadid=12884;start=msg119573#msg119573 date=1079043787]
    [/quote]
    Well, I think I missed the lucky and the smart on this one at least so let me ask, is the consensus that unless things start to liquify and leak that it is okay to have the M1 in the plug part of hte knuckle? Thanks, I'm just wondering and I'm just worried about it. Any advice as always is appreciated immensely.
  15. Beowulf
    Beowulf
    12,529
    55
    Mar 27, 2003
    TC,
    I'm not sure you'll get a consenus on *anything* around here, but my vote would be to leave it alone unless you see a problem. Start using a moly in the plug (though it won't get to the birf from there.)
    -B-
  16. turbocruiser
    3,562
    27
    Dec 24, 2003
    [quote author=Beowulf link=board=2;threadid=12884;start=msg119615#msg119615 date=1079048841]
    TC,
    -B-
    [/quote]
    Thanks, B , I appreciate it.
  17. Pitbull
    Pitbull
    682
    3
    Oct 31, 2003
    Go here www.bobistheoilguy.com look under the lube section. These guys are experts at lubricants and can answer any question you might have. They have degrees in lubrication. :)
