MLS head gasket?
Discussion in '40- & 55-Series Tech' started by amaurer, Feb 20, 2009.
  1. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    Forgive me for cross posting from the diesel section, but this is a general issue.
    Due to a shoddy, and unnecessary, previous head gasket replacement, I'm experiencing the fun all over again. This time I got an OEM head gasket and was surprised to find that the new gasket is MLS (multilayer steel) (the original p/n has been superceded several times)
    I know MLS gaskets are superior in many ways, but I've heard they're very picky about flatness and low-roughness surfaces. While I have had the head resurfaced, I wasn't expecting an MLS gasket so I didn't pay any attention to the finish the shop created. I also have no real way to resurface or even measure the block's flatness (short of pulling the whole engine - but this is my DD and I've been already down for a week).
    So, am I in for trouble with this MLS gasket, or does Toyota know best?
  2. bsevans
    bsevans Focus on the Journey
    2,008
    Media:
    50
    Albums:
    1
    31
    Jun 9, 2005
    Southern Arizona
    I guess I need to be schooled on what a MLS gasket looks like. Could you post a photo. I know that Toyota went from head and manifold gaskets that were metal (dimpled) on the contact surface (both sides) to a non metalic contact layer on both sides. If your gasket has an exposed metal layer then you have the old style gasket.
  3. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    i can snap a pic tonight, but this is not the old dimpled style. MLS gaskets are several layers of flat (non dimpled) steel thats been coated with black rubber (ok, its fancier than rubber, viton i think).
    the original gasket and my first aftermarket replacement were dimpled. this one is smooth, has a viton coating, and feels heavier/stiffer. it has the right pn stamped on it, and is the right dimensions, so no question there.
    do i use all the same torques and such too?
  4. bsevans
    2,008
    Media:
    50
    Albums:
    1
    31
    Jun 9, 2005
    Southern Arizona
    That's the HG I used when I had a valve job done. Same torque and then re-torque after the engine idled at temp for 15-20 minutes. I like the new design and feel it will seal better than the dimple design.
  5. ranger
    ranger
    1,169
    7
    Jan 18, 2003
    Mountain Hole, Idaho
    You can measure the blocks deck surface with a straight edge and feeler gauge.
  6. Rice
    Rice
    4,631
    Media:
    10
    Albums:
    1
    5,765
    May 2, 2003
    GSO NC
    You should have no trouble with the MLS. While the big advantage is their ability to seal metals with different expansion rates they also do well with like metals. Regardless, if this is your second time doing the job certainly take the time to verify a flat mating surface.
  7. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    well, its in there now. heres a pic of the gasket for posterity
  8. grant5127
    grant5127
    5,025
    17
    Oct 31, 2003
    Meridian,TEXAS
    Thanks, DuPont!
    Most late model engines now use Multi-Layer Steel (MLS) head gaskets because they are much stronger and more durable than nonastestos or graphite cylinder head gaskets. Aftermarket MLS head gaskets are now available for many "problem" engines that are known to eat head gaskets............
    MLS technology was developed to overcome sealing challenges. The number of layers in an MLS gasket ranges from two to five, depending on the engine's sealing characteristics. Generally, the more layers, the more motion the gasket endures.................
    Felpro now has introduced the "New Breed" (PermaTorque) mls head gaskets that requires no re-torque installation............:clap:
    Man, I gotta say; They sure got close with the hole punch on your gasket there...
    Are the fire rings distorted enough to cause worry?
  9. bsevans
    2,008
    Media:
    50
    Albums:
    1
    31
    Jun 9, 2005
    Southern Arizona
  10. grant5127
    grant5127
    5,025
    17
    Oct 31, 2003
    Meridian,TEXAS
  11. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    The design of the fire rings is kinda funny, unlike on a composite gasket where the ring is a metal ring that surrounds the cylinder and then is folded back over the upper and lower surfaces of the gasket, on this one the rings are formed by the uppermost steel layer of the gasket wrapping through the holes and then bending back over the other layers.
    So what you're seeing is the side without a fire ring per se; you're seeing the side of the gasket that bends down through the holes. The difference in coloration aren't from fire rings, for some reason they saw fit to not apply the rubberized coating in those areas.
    Here are two zoomed in pictures of the top and bottom of that spot near the "fire ring". The top photo is the top of the gasket, which folds down through the cylinder holes - you can see it just looks close because of some spurious rubber. The botton photo is the other side, which shows the upper layer folded back onto the lower face.
  12. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    A little confused on the re-torque. Do I idle until the engine is at temp (going to take an HOUR!) or do I bring it to temp with some driving and then idle for 15-20? And do I let it cool before retorque or do it hot?
  13. malcb
    malcb
    577
    Jan 14, 2007
    Stafford - UK
    Would it get up to temp faster if you restricted airflow through the rad?
  14. amaurer
    amaurer
    4,459
    89
    Sep 3, 2007
    Longmont, CO
    Maybe, maybe not. Tstat will be closed while warming up so radiator shouldn't be doing much.
    EGTs while idling are only ~180F, there just isn't a whole lot of heat available.
  15. donny paradise
    donny paradise
    613
    Jan 3, 2006
    Paradise
    What is the torque on those diesels? :confused:
