Toyota 11115-58110 (1111558110) GASKET, CYLINDER HEAD. New & genuine Japanese car parts. Fast shipping. Low prices. Request a quote from Amayama Trading Co. online.
Thanks guys.
It has Gturbo that uses standard gaskets. I have been running it with no boost controller/waste gate action and it has worked well for many years.
I was not sure if MLS had any non-metal layers. I have never seen one.
I recently bought 11115-58110 from partsouq and can confirm it was a true multi-layer. The head gasket i removed from my engine was weird...it was the same part number but felt like it only had maybe 2 layers. I want to say the new partsouq one had at least 3 layers.
At least you know the partsouq stock is the good one.
Thanks guys.
Have you had head gaskets issues? My 13BT is using water, but passes hot and cold pressure tests. Has been running 22-28psi boost for near on 15 years.
About turbo gaskets, I recently sourced them for my 15B-T which has the later -58020 turbine housing as found on the 1HD-T and -FT. The 14B-T/15B-T specific gasket kit is NLA, but all the OEM gaskets are available individually (and expensive).
The 13B-T gasket kit is probably NLA, but a 12H-T kit should fit as they also use the earlier -58010 turbine housing.
How come you are looking for gaskets for a later engine?
