misterious air sensors on HDJ80
Discussion in '80-Series Tech' started by andrea-PE-ITALY, Aug 14, 2006.
  1. andrea-PE-ITALY
    andrea-PE-ITALY
    123
    1
    Aug 14, 2006
    italy-abruzzo- città sant'angelo-
    on the top of the 80 diesel engine there are some 12v relais connected to some black rubber tubes for air. I saw the turbo pressure sensor in the back of the air collector. Im' sure one of these sensors works with air depression for increasing of minimum with A/C activated. What are the other sensors? two of them are located behind the bottle of idraulic oil... Is there anybody who knows it??
    Tanks a lot from ITALY
    Andrea
  2. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,122
    1,250
    Apr 4, 2003
    Panamá
    HI Andrea .. if you post it in the Diesel seccion for sure you could get a better luck !
  3. 94landcruiser
    94landcruiser
    1,067
    3
    Mar 6, 2006
    Westwood, Ca/Ixtapa MX/Ahwatukee, Az
    Benvenuto Andrea!
    I have no clue but if you swap engine/tranny/assorted necessary systems with me that will take care of your problem!
    :D
  4. andrea-PE-ITALY
    andrea-PE-ITALY
    123
    1
    Aug 14, 2006
    :) sorry but i have not another HDJ80 engine :)
    thanks all for answers...i hope it is correct...
  5. RoddQLD
    RoddQLD
    211
    1
    Jul 18, 2005
    Queensland, Australia
    On the side of the air cleaner is an air pressure switch that turns on the 'blocked air filter' lamp (on dashboard) if the aircleaner is blocked.
    I'm not sure what others you are referring to. If you can post a photo it may help.
  6. andrea-PE-ITALY
    andrea-PE-ITALY
    123
    1
    Aug 14, 2006
    these are the photos about misteriously air valve, the couple is fixed on the air collector. the single valve is behind air collector. it is a vacuum electric valve with label TOYOTA 25819-17010 139700-0260 E-VRV. i'm lookin for scheme with their connection because i think i made a mistake unmount them
