- Location
- United States
ORIGINAL OWNER 2004 Landcruiser (100 series) - 110k miles - Great Condition - $28,500 firm/as is.
Send me your email address and I will email more pictures (only 5 allowed here).
Comes with all listed below (no substitutes or subtractions - please do not ask).
Accessory Upgrades
New ARB Awning with 2500 x 2500 Deluxe Awning Room with Floor, new ARB rooftop tent with Simpson Annexe, new Front Runner roof rack with 1 cargo strap and axe holder. 3 Rotopax 3 gallon gasoline cans with extension attachment for Front Runner roof rack. New Key cases. New Hood lift support shocks struts. New rear door lift support shocks. MAXSA Escaper Buddy Traction Mat (Set of 2) for Off-Road Mud, Sand, & Snow Vehicle Extraction Orange.
New side by side ARB sliding drawers with a refrigerator slide on the right drawer. (All of the original seating comes with it if you want to remove the drawers). Does not come with the Sirius XM radio.
Electrical Upgrades
Dual battery system with Redarc SB12 Battery isolator kit (12V100a) and Redarc BCDC1240D (12V40a) auxiliary battery charger. Dual battery system hooked into a Power Bright PW2300-12 Power Inverter 2300 Watt 12 Volt DC To 110 Volt AC mounted in the rear. Blue Sea 5025 ST Blade Fuse Block with Cover (6 circuit) connected to the dual battery system and onboard ARB CKMA12 High Output Air Compressor (with ARB 171302 Inflation Accessory Kit). Fastronix heavy duty push button momentary start switch in cab (separating the batteries at start). MICTUNING LED Digital Double Voltmeter for monitoring both battery voltages in the cab.
2 x 7.5'' 36W Flood LED pods Off road Driving Lights (Work Light /Spot Flood COMBO wired with Eyourlife Heavy Duty wiring harness with Remote Control ON/OFF Strobe Switch Universal Fit For Driving Fog Light Work Light.
Suspension Upgrades
New OME heavy duty rear coil springs, new oversized tires, new front and rear lateral control / torsion bars, new heavy duty front upper (inner) control arm and lower (inner) control arm.
Accessory Upgrades
Electrical Upgrades
Suspension Upgrades
