Misc F & 2F parts (1 Viewer)
pappy
photosynthesizing
Moderator
Too far north. Too far east.
I have the following parts:
From 1969:
3-speed flywheel, $40
3-speed bellhousing (missing lower cover), $35
3-speed clutch fork, $10
From 1978 2F:
Top water neck (thermostat housing), $10 [SOLD]
Water pump/fan pulley, double, $25 [SOLD]
Fan, $10
Fan clutch, $15
Pics available on request. Shipping by FedEx Ground from 87120, Albuquerque, NM. PM or email to ratstew@comcast.net
I'm interested in the thermo housing and the fan pulley. I'll contact you direct.
Thanks.
Todd Bull.
Will the fan clutch bolt up to a 1F water pump? I've just complete a P/S conversion, had to add a double fan pulley now the fan won't bolt up with out a spacer. i'm thinking a fan clutch will move it out several inches.
Don't know. Is there a measurement I can take?
At the end of the pump housing there is a 4 bolt pattern with a center line deminsion of 1.5". The over all projection needs to be less than 3" from the pulley out towards the radiator. There is also a 1" od projection in the center of the pump that the original fan was centered on that the fan clutch will need to go over.
I sent you a PM.
Top
