mini truck hub/rotor seperation
320t
Tempe, AZ
Anybody wish to school me on the secret to seperating/splitting the hub and rotor from a mini-truck? We've gotten the 6 lug studs pressed (hammered) loose. But there appear to be two smaller (maybe 7.5 mm) bolts that appear to be round headed also attaching the hub to the rotor. What be the best way to get these out and is there anything else that will need to be done to pull them apart. My rig came already converted and the high schooler who's project this is is getting frustrated with my rookie wrenching and lack of applicable experience in this conversion. Something about a 15 year old having zero patience. Thanks
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
Well,
The bolts that you talk about, SHOULD NOT be of a round head, if they are still stock, unless someone tried to remove them previously, and jacked them. They should be a 14mm head fastener, and come right out with a ratchet and socket. If they are rounded, you most likely will need to have the heads drilled off, so that you can get the rotor off, and then work at getting the remaining part of the bolt out after.
---I am not a crapsman tool guy at all---
Now, with that said, they have some sort of socket that grabs rounded heads of bolts and might be the ticket for this....
As far as the 15 year old....tell him to clean something.
Good luck!
-Steve
ken_79-fj40
New Hampshire
Yeah, the bolts on the backside just come out (I usually just use my impact and a deep socket) and you bang the old rusted rotor off the hub.
320t
Tempe, AZ
14mm? no way. These boly heads look to be 7.5 or 8 mm and are recessed in the hub.
Poser
s-Moderator
Supporting Vendor
MN
Got a pic?
320t
Tempe, AZ
I'll try to get a pix, the bolts I'm talking about are recessed on the hub flange between the wheel lug studs.
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
They sound like centering pins to me. Not bolts.
320t
Tempe, AZ
ok if they are centering pins, do they need to come out? if not how do I split the hub and rotor so I can upgrade to the vented rotors? Still working on the pix Thanks all
