mini truck disc conversion. what about steering arms? (1 Viewer)
Utah
well i've come to the point where a decision needs to be made about the steering arms on my 40. high-steer is not in the immediate future so it's looking like i'm going to have to weld, drill, and ream the hilux arms to fit the fj40 tie rod ends. i figure i will weld (mig) and drill them myself, then find a machine shop that can do the taper for me.
is this the normal way of making these parts work together?
if so, should i just buy my own reamer?
is there any other economical way of getting everything to work?
thanks!
1973Guppie
Supporting Vendor
"the whale's vagina", CA
Website
www.noahsarkstlc.com
I always just use the minitruck arms, one side needs to have the U shape cut from it, then you can use some tapers for the arm holes so they work with stock fj40 tie rod ends, etc.
pappy
photosynthesizing
Moderator
Too far north. Too far east.
No need to bubba the arms. There is a Toyota solution. A buddy just did this. Actually, I did the work, but he bought the parts. He used the large pattern arms from a newer model FJ40. I think they were 1979+. They were a bolt on with no issues.
If I remember correctly he bought them from Kurt at Cruiser Outfitters.
orangefj45
Supporting Vendor
norcal
another option are tapered billet steel inserts. i stock them along with everything else needed for a disc brake swap or knuckle rebuild.
hth
georg @ valley hybrids
lcwizard
Supporting Vendor
Supporting Vendor
Miami, Arizona
Website
www.4plusproducts.com
Or.. convert to FJ60 rod ends. It will require custom tie/relay rods
1973Guppie
Supporting Vendor
Website
Bubba? sure, if you want to spend extra $$ for no reason, there are other solutions, BUT a few minutes with a grinder with a cut off wheel will save you some money.
Noah
Kansastitty
This is what we did and it has been fine. Cost next to nothing as well.
If you call $4 nothing! Geeze, where do you guys get all this discretionary income????:rolleyes:
Wilton, Ca
I have two welded double steering arms for sale if you just want to buy one instead of building it. One has the larger mini truck/FJ60 TRE holes and the other has the smaller FJ40 TRE holes. PM me if you are interested.
