mini p/s question
I've searched and did not see an answer to this specific question. Since the mini truck ps pump is longer, is there enough clearance between the rag joint and fender to mount the box without needing to trim the fender? My current steering shaft was cut so I don't have the existing rag joint to measure from. Just in the planning stages now. Thanks, I know many of you have the answer to this.
When doing a mini PS install the position of the rag joint does not change. I also didn't have to modify my fender when I did my conversion.
