mid 90's gm steering box??? (1 Viewer)
Clarkdale/flagstaff
i put one of these newer gear box on my 40 because they are easer to get and my 91 4.3 bolted to it ! that said has any one cut the steering stops out of the gear box?? i would really like to do this it gives extra turn rad. right now i dont come close to the bump stops:frown: on the axel
I suppose next time around you'll be more careful and choose the correct box :hmm:
if it was legal i would have justwelded another inch on the pitman arm!
Sort of answered your own question. Locate a longer saginaw pitman. Gm, jeep, or ? Just measure your box shaft and head for the junk yards.
weld pitman arm?
So it's not legal to build your own Pitman? I made mine out of 3/4" strap, welded the splined socket from the stock one in a hole so it's all surrounded with a 360 degree weld. Is that illegal? Why wouldn't it be safe?
Where in the world is it illegal to modify your truck? You live in California or something? I work in a trailer manufacturing plant and we do stuff like that all the time, never thought it could be illegal.
i was told welding your pitman arm was jut a illeagal as driving bead locks on the highway i havent been pulled over yet:hillbilly:. so the you guys think modifying the arm is easier than messing with the box
DYI Pitman
In my uneducated opinion, my pitman is about 3 times as strong as a stock one. I carefully measured the travel and the drop and made just what I need. (This was after half a day at the junkyard looking but as far as I could tell what I needed had never been mfg'ed by anyone).The taper for the TRE is an easy to find reamer, the hardest part was bending 3/4 X 3" strap in a nice neat way.(my torch is a little small to heat that)
I live in Montana, nothing's really illegal here. maybe California might be.
