- Thread starter
- #21
your night switch is on the ground side ? , if so you won't have it light up unless the switch is on or you put it directly on the - terminal .
i think you have a big dead short in your wiring , one of the heaviest gauge wires you have most likely . it is grounding out , rubbed through or something . start at the battery + and work your way down till you find the melted / burned / grounded / wire .
if your night switch was on the + side i would of possibly blamed it but you are usuing it on the - side so there is nothing wrong with it .
yes, kill switch is on the ground side - I always had it that way from the day I installed it. my logic was it is better to disconnect ground first, so it made sense to put disconnect into the neg cable.
I will check the + cable from battery down to the solenoid, but I am pretty sure it is perfect. could it be the solenoid since that is what the biggest power wire is tied to?
if I do not find that fat + wire off the battery too be bad, how do I go from there in finding the "short" - hundreds of feet or wire in a 30+ yr old rig hacked together by numerous owners... how do you even start or process it?
