Megasquirt info
Discussion in '60-Series Wagons' started by Rescue Wagon, Feb 18, 2009.
  1. Rescue Wagon
    Rescue Wagon
    285
    Jan 1, 2006
    Cheyenne, WY
    Has anyone installed a Megasquirt with either a 3FE or a 2FE?
    I have done a search and haven't found anyone who has actually completed the install. I already have the truck completly gutted so I would like to figure out what it would take to us a Megasquirt vs the stock ECU.
    Thanks,
    James
  2. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    Megasquirt? Why not stick with the stock ECU?
  3. LCOwner
    LCOwner
    901
    3
    Jun 23, 2002
    Madera, CA
    Do you want to use the 3FE head and intake? If so I'd just use the OEM. If you're going to use a 2F manifold and some sort of TBI, Mega may be worth your time
  4. Rescue Wagon
    Rescue Wagon
    285
    Jan 1, 2006
    Cheyenne, WY
    I plan on using all the 3FE fuel injection system to make a 2FE. The reason I want to go with the Megasquirt is to be able to program in the changes I make to the engine. From what I know about the stock ECU is it is a closed loop system and not very friendly to aftermarket changes.
  5. ntsqd
    ntsqd technerd
    5,472
    326
    Apr 26, 2007
    Upper So. CA
    Closed loop does not mean that it is intolerant of re-programming, but being a proprietary ECU that probably hasn't been hacked I doubt that much can be done with the stock ECU.
    Are you set specifically on a MegaSquirt? There are other systems out there in the lower price part of the market. SDS comes to mind.
  6. LCOwner
    LCOwner
    901
    3
    Jun 23, 2002
    Madera, CA
    When I was considering MS, the thing that changed my mind was the "what if" What if the ECU burns a diode or relay when I'm out 2 days on a 4 day trail. At least OEM has limp home mode. MS cool for street and track, bad for trail IMHO
  7. Rescue Wagon
    Rescue Wagon
    285
    Jan 1, 2006
    Cheyenne, WY
    I can see your point about limping home.
    I am not dead set on MS, but from what I have read on other forums their new v3.0 it top notch. My plan to deal with limping home is to leave the stock ECU in place and if something goes wrong with the MS I can just plug back into the stock ECU. It is not that straight foward, but I saw a post on another forum where someone explains how to make this work.
  8. matt.mcinnes
    matt.mcinnes 2F-ETI
    2,373
    76
    Jan 11, 2006
    Melbourne
    I looked at M/S but lacks scope went with a Wolf V500 ECU.
    The way the Aus $ is they would be relatively cheap at the moment.
    All depends on budget though.
  9. Rescue Wagon
    Rescue Wagon
    285
    Jan 1, 2006
    Cheyenne, WY
    What about the MS did you not like?
    At $1,800 even with a good conversion rate it is still nearly 5 times the price of the MS. My plans are to run a 2FE with the only mods currently being a RV Cam, Chevy short block valves, and headers. I don't have any plans to run a turbo or a supercharger, so I am not sure if the $1,800 is worth the investment.
  10. matt.mcinnes
    matt.mcinnes 2F-ETI
    2,373
    76
    Jan 11, 2006
    Melbourne
    I can get one for under $1400US but yes not cheap compared to M/S. I does support boost applications better too. Like I said all depends on budget.
    Matt
  11. stereophile33
    stereophile33
    200
    3
    Dec 28, 2005
    Portland, OR
    I have a wolf acount and we can get them for ~$1200 if anyone is interested
