- Thread starter
- #521
Hard fought battle tonight. I've never seen one give up that much of a fight.
The thought rattled around in my head as I have my H42 just sitting around but decided I would like to keep the auto.Now would be the time to say ...hmmmm, where can I get my hands on a manual transmission and how much would I have to cut to make fit?
Would you have to cut the drive shafts?
That's great thinking, Thanks. The assembly for the A442 came in yesterday and the springs are almost identical. They are a couple hundredths shorter and instead of 22 individual springs with a separate ring that sits on top it's all kind of one piece. The A442 and A440 have the same internals (same plates, clutches..and same amount of them) at least on this subassembly. The oil pump is the same part number...so...I am deducing the spring rate is the same and it will work fine.just did the pan on my 55... FIPG is a MUST. no comparison to black RTV. Does the AT manual give the specs on those springs? I'll bet a spring MFG has some on the shelf, or could fab some cheap-ish if you had the rate gauge, and free length...
I don't think it's going to be an issue, they should be 1.23" and they are 1.214ish. About 1% length on a stiff spring that's always under compression.could you shim to get proper length?
Interesting to find that, I haven't pulled any of the rod caps yet.That bearing looks new
Haha, Thanks. Maybe a shade tree dentistry business is in order. Dremel, shop vac, pliers, scribes, inspection mirror, and an air compressor..just need to rig up a big magnifying glass to the headlamp and all set.The work you do Marc is amazing. You could teach a few of us some very pertinent skills! Dirty to clean workspace. Seems to me you could be in the medical field w/ that understanding.
Just gotta say you inspired me to do the same to my 60 cruiser. After reading your thread. So I wet sanded it and polished it and results where amazing.We have been hitting it with different cleaners and polishes in between projects. It's hard to get a good pic in here but the paints in pretty good shape..on 95% or so..
