Hi all, new to the forum. My 84 4 speed with the 2F has been amazingly reliable for the 8 or so years I’ve owned it but in the last few months I’ve had consistent fuel problems.
Initially I isolated the original fuel pump as being the problem when it was mounted on the block, so I replaced it. That seemed to solve the problem but a few months later, I experienced the same issue of fuel not reaching the carb after driving for some time. Turned out to be the fuel pump again. I put on an electric universal fuel pump to get home, and realized that when I remove the old and new mechanical pumps, they work when I manually press the lever, but mounted up with the spacer and gasket they don’t.
Could it be that my cam lobe is worn down, chewed up, or otherwise unable to press the lever anymore?
