Mechanic says cylinder 3 very low Compression
Raleigh NC
So I have been dealing with a misfire in cylinder 3, which the mechanic says it has very low compression but didn't give me the numbers,
but I checked compression before the shop did, and all cylinders show 180psi this was before and after I had the head off for a valve job. The misfire was present before the valve job, when I put everything back together still same misfire, I have checked and tested just about everything Im leaning towards EGR stuck open? because with vacuum applied the engine does NOT STUMBLE or stall but would that effect only one cylinder?
1997 LX450 332,000 MILES
flintknapper
Deep East Texas
First thing to do would be to do your OWN compression test and record results.
I have similar numbers on all six cylinders (engine at 326K miles).
retrofive
rɛtrəʊ
meridionale oregon
Sounds like he did "I checked compression before the shop did, and all cylinders show 180psi this was before and after I had the head off for a valve job"
flintknapper
Deep East Texas
I read it to mean he checked compression before and after head work....then subsequently took it to a mechanic and mechanic says low compression on cyl. 3
Perhaps OP can clarify.
Raleigh NC
So.....the 'mechanic' was wrong about low compression on cyl 3?
Yes very wrong, and he told me not to put anymore money in my engine and to get a used one, yeah ok NOT.
I should have went with my gut and replaced the injector when this started but they all checked out, that is what threw me off
all new OEM injectors has it running smooth at 332,000 miles.
ATL
Sheesh… just goes to show you that, regardless of profession, there are good ones and there are bad ones. I can hear the conversation now “buddy, you need to replace this engine. We had a guy in here yesterday with a Ford Tempo and with the exact same problem…..”
east coast Canada
I trust very few mechanics after all the s*** work I have seen over the years. I have meet a few good ones but also seen and tried to be BS’d too by many.
Funny thing is quite a few bad ones were “factory trained technicians” at Toyota 🤦‍♂️
I do 99% of all mechanical work on my machines.
