MC outfeed line reversal question
In a van down by the American River
Does anyone know if there is an actual difference inside the MC between the front and rear piston cylinders that might prevent the switching of the circuits so that the stock front brake line coming off the MC now feeds the rear disks, and vice versa. I am also running a proportioning valve for the rear line, and also switched the lines where there tee on the frame rail. seems like it should be ok (especially with the p valve in place ) but I will defer to experts. BTW, application is following a rear disk install and it was easier to switch the lines for the p valve install, instead of having to run a complete new line up from below along firewall, etc.
Thanks
