Dissent
Questioning my life choices...
I installed a new OME steering damper today along with a HD relay rod and tie rod. The rod behind the wheels is still 45" like the original. The rod in front of the wheels was 43.5" when I installed it. I centered my steering wheel by adjusting the front rod and now the wheel and discs are nice and straight. I then adjusted my lock to lock stops on the birfs and they were off by about 1/8". The right side hits the stops now and no longer strains the steering components but the left side stop about 1/2" shy of the stops. Turns out the OME steering damper is maxed out. I pulled the truck end off and sure enough, the stops hit fine. The damper is 1/2" too short. I can't believe this is normal.
Now the rod in front of the tire is longer to align the drive wheels with the steering wheel. Originally my steering wheel was about 30 degrees off when the truck tracked straight. This probably has something to do with it but how else is it supposed to be setup?
Anybody run into this maxed out damper before??
