"Maude The Lexus"
2001 Lexus LX470
Current:
Purchased via eBay Feb 4, 2016 with 135,463 miles for $9,350.00 ($10,110 otd)
from Best Motors LLC 3515 Lakeside Ave Cleveland, OH
Here shots from the eBay ad:
She was pretty near flawless when I picked it up.
Most relevant maintenance (many oil change records missing but consistently changed)
11/22/08 - 58,751
2001 Lexus LX470
Current:
11/22/08 - 58,751
- NAV Update
- Ignition Housing
- Steering Shaft Assembly & Sub Assembly
- AHC Flush
- Power Steering Flush
- R Side Manifold & Gaskets
- Fan Clutch/Fluid Coupling
- All Struts
- RF & LR AHC Sensors
- Sway Bar Links
- Rear Hatch Handle
- Fixed Lumbar Support
- Exhaust Manifold Gasket
- 2001 Lexus LX470 Purchased by Das Shtig on eBay for $9,350.00++++ TOTAL: $10,110.00
- R&R Freon
- Service performed by Pops Auto
- EP S5516B - Battery
- R+R Rear AC Unit Low + Hi Side
- Rear AC Unit Connector
- Rear AC Hi Side Line
- Work Performed by Pops Auto
- Vehicle Inspection @ Firestone Casselberry
- Toolkit Parts Purchased
- 0911460070 - Extension Sub (x2)
- 0911560060 - Rod, Jack Ha
- 0915060030 - Wrench, Hub Nonstk
- 0911660010 - Lever Sub-Assy
- JP 9008036067 - Front Wheel Bearing
- OEM Oil & Filter Change
- 8907253200 - Key
- JP 2100565 - Alternator
- Rear Brakes
- Tires Mch LTX M/S (x4)
- 5190060194 - Spare Tire Carrier Assembly
- Sway Bar Bush (6 Parts)
- JP 9094801003 (x4)
- JP 4884960010 (x2)
- DE 3297 - Spark Plugs (x8)
- 8161060220 - Lamp Assy, CL
- 9008019027 - Ignition Coil (x1)
- 4882060032 - FR Link Assembly (x2)
- 4881560111 - Stabili Bush (x2)
- Magnetic Phone Mounts Installed Front and Rear
- JP 1780150040 - Engine Air Filter
- Flat Repair
- Rotation & Rebalance
- Performed by Discount Tire, N Semoran Blvd
- Hose (x2)
- JP 9094702F25
- JP 9094702F26
- JP T150 - Fan Clutch Bracket
- Upper & Lower Control Arms L&R
- JP 4861060030
- JP 4862060010
- JP 4864060010
- JP 4863060010
- JP 4551760010 - Steering Rack Grommet
- *Weld* Sway Bar Mount
- Rack & Pinion R&R
- Front Main Seal
- Timing Belt
- Seal
- Bushing Kit
- Parts From Triangle - Service by Pops Auto
- JP 1356809070 - Belt
- 9008082050 - Fuse, Mini
- Tie Rod Ends (4 pieces)
- JP TE13591R
- JP TE13591L
- JP 3016010001 (2x)
- JP 1220450020 - PCV Valve
- JP JVS10451 - Valve Cover Gasket Set
- JP 243407F000 - Positive Battery Terminal
- Installation by Pops Auto
- 2100565 - Alternator
- 8710360250 - A/C Blower Motor
- Installed by Pops Auto
- Oil Change
- F&R Diff Fluid Change
- Transfer Case Fluid Change
- Interior Shampoo & Dry
- Rust Remediation
- Perfiormed by Pops Auto
- Duralast Starter @ Tires Plus
- MS96333 Int Gasket Set - Upper FLPRO
- Wheel Bearing (FL)
- Power Steering Pump
- Diff Bushing
- Performed at Pops Auto
- Flat Repair & Rebalance
- Tire Replaced - MCH/LTX 275/R70/R16
- Right Front Tire Replaced with Spare
- 5 Wheel Rotation
- All Perfomed at Discount Tire on Semoran Blvd
- DS Rear Tire Leak Repair
- Resurface Front Rotors
- Front Brake Pads
- N100 546502 Wheel Seal (2x)
- Body Trim Clips:
- 9046712071 - Clip (5x)
- 7539630160 - Clip, Outside (2x)
- (x4) Tires - Kumho Road Venture AT51 285/75/16 - Purchased barely used from ih8mud member
- Mount and balance (x4)
- 2-year Alignment @ Toyota of Orlando
- 4343060040 - Front CV Axles (x2)
- 9008082021 - Fuse, Mini
- 8487060080 - Power Folding Mirror Switch Assembly
- Replaced Missing Seat Screws
- 27060-50260-84L - Alternator @ Toyota of Orlando (Warrantied)
- 4-Wheel Alignment
- Multipoint inspection
- Service performed by Pablo Cruz
- Front R+L Shock Absorber - Replaced by Lexus
- AHC Flush performed
- All Front End suspension Torqued to Spec
- 15790022 - Air Filter
- 21299437 - Cabin Air Filter (2x)
- 9046709093 - Clip (2x)
- JP 613207 - Hood Strut (2x)
- Gallon of Antifreeze
- Coolant Flush performed
- JP 2100565 - Alternator RETURNED to Triangle Auto Parts
- 8724860460 - Pipe, Water
- 280-0320 - OEM Starter (Warrantied @ Tires Plus)
- Dealer tried to find and fix "clunk" -- they failed to determine source of noise
- Dealer Retorqued All Front End Components to Spec
- When I picked up my car, the AHC pump was broken. Dealer declined to replace.
- 41110-60880 - Rear Differential -- NEVER INSTALLED
- 4342160060 - Flange, Front Axle
- Aisin Fan Clutch
- Front Cupholder Arms (TrunkNets - Amazon)
- Denso A/C Compressor w/Clutch
- Re-Attached Glovebox Dampener
- JP 1640050290 - Denso Radiator
- 1671150090 - Fan Shroud
- 002721LLAC01 - Antifreeze Gallon
- JP 31336 - Cap
- JP 88711-60470 - A/C Low Pressure Line
- 8837160390 - Suction Valve (AC Compressor)
- OEM Synth Oil & Filter Change
- YotaMD Titanium Key Shell (x2)
- SB3812 - DS Front Lower Ball Joint 555
- Syn ATF Mobil ATF
- OEM Bottle Jack & Complete Toolkit - ebay
- 5142060010 - Cover Assy
- 7760660120 - Protectector Su
- Master Key purchased from eBay
- Owl Expedition - LED Puddle Lights
- 90520-31009 - Snap Ring
- 04466-60070 Pad Kit, D 757
- 42431-60281 Disc, RR SPORD (2x)
- Oil & Filter Change
- Tire Rotation
- Lexus Logo Chrome Tire Stems
- Land Cruier Engraved License Plate Frame
- Air Intake Ram Snorkel Kit
- Lexus Factory First Aid Kit
- All ordered from Amazon
- 9010508304 Bolt, Washer (4x)
- 9008046209 Clip (2x)
- 9046805131 Clip (4x)
- 4771560010 Pin Cylinder (2x)
- 4771560020 Pin Cylinder (2x)
- Toyota TrueStart Battery
- 90982-05035 Terminal Assy
- 90467-07201 Clip (4x) (Left Fender Liner)
- 0446560220 - Pad Kit, Disc
- 4351260171 - Disc FR (2x)
- 4342260070 - Gasket FR Axl (2x)
- Front Brakes Replaced by AutoNation Toyota Winter Park
- Oil & Filter Change Performed by AutoNation Toyota Winter Park
- Multi Point Inspection performed by AutoNation Toyota Winter Park
- 1121350031 - Gasket Cylinder
- 1121450011 - Gasket Cylinder
- Valve Cover Gasket Install by Juan Jimenez
- 9031170011 (2x) - Wheel Seal
- 9008036067 (2x) - Wheel Bearing
- 9008036098 (2x) - Inner Wheel Bearing
- Wheel Bearing Install by Juan Jimenez
- 4342335010 - Cap FR Axle O (2x)
- 7555760010 - Moulding, Roo (4x)
- 6187560020E1 - Lid, Spare Wheel
- 1763016040 - Air Control Valve Assy
- 00279000T401 - ATF T-IV Quart (6x)
- 9913212050 - Bulb (2x)
- 3533060030KT - Automatic Transmission Filter Kit
- Transmission Fluid Drain & Fill Performed
- 8162160200 - DS Corner Light
- AHC Pump Motor
- Techstream Cable
- 4 Wheel Balance and Alignment performed by Toyota of Orlando
- 1657150150 - Hose, Radiator
- 00718-ATF00 - ATF
- DS Upper Ball Joint 555
- SUN 3402991 - SUNSONG Power Steering Return Hose
- HighlandExpeditionOutfitters DS 270degree Awning
- 9008019027 - Coil, Ignition
- 9008091180 - Plug, Spark (8x)
- 9010114021 - Bolt, Hexagon
- 91641H0632 - Bolt, W/Washer (2x)
- 9017814003 - Nut, Flange (2x)
- 9010514121 - Bolt, Washer (2x)
- 9017020003 - Nut, Hexagon (2x)
- 4 Wheel Balance Performed by Pep Boys Casselberry
- 43851057442 - Steering Rack (OEM, refurb)
- 4504669195 - 555 Tie Rod Ends (2x)
- 4432730030 - Gasket, Pressure Hose
- 5890760051 - Hinge Sub Ass (Front Center Armrest Hinge)
- 8123133010 - Lens, Courtesy (F Pass Door Courtesy Lens)
- LED Halo Black Projector Headlamps
- Front and Rear Mudflaps
- Purchased From eBay
- Rack & Pinion, Tie Rod Ends, & Related components installed by by Jose @ Select Cars
- Alignment Performed by Toyota of Orlando
- 1569250020 - Oil Filter Housing Gasket
- JP 166040F010 - Upper Idler Pulley
- 1220450020 - Valve Sub Ass
- 9048018001 - Grommet
- 1780150040 - Element Sub A
- 8856860010 - Air Filter
- 9011906330 - bolt w/washer
- New Escort Radar Detector Power Cord
- Cabin Air Filter DENSO
- LR spark plug r&r and new coil installed at Autonation Toyota
- New Headlight bulbs from Advance AP - Silverstar ZXE2
- K&N coupler for snorkel prefilter
- OEM snorkel prefilter installed
- New Toyota TrueStart Battery installed at AutoNation Toyota under warranty (24 month beginning 4/2/19)
- Oil Chage at Lexus
- 9011914090 - Bolt w/washer
- 4165160010 - Cushion, Diff
- 4165360010 - Stopper, DIff
- 4165404020 - Stopper, Diff
- 9011908862 - Bolt, w/washer (x6)
- 4 Maxxis Razr MTs 285/75R16 purchased on ebay
- 4 Maxxis Razr MTs 285/75R16 installed at Pep Boys
- Lifetime Alignment purchased at Pep Boys
- Purchased collision repair manual
- Ball joint service ?????? details
- 1787550280 Air filter resonator (?)
- CV Axle w/lifetime warranty at Triangle Auto Parts
- 9538103025 - Cotter pin
- 9017114010 - Castle nut
- 9094202083 - Bolt, Hub
- Tightened wheel bearings
- Broken lug removed and replaced
- Service performed at Cech Bros
- 9031147013 - Seal, type spord
- 90311-47027 - Seal type spord
- 9008036067 - Bearing, t spord
- 9021442030 - Washer, cl spord
- 4352160011 - nut, fr wh spord (x2)
- 9021542025 - washer, lo spord
- 4342260070 - Gasket, fr spord
- 9046720010 - Clip (2x)
- 1226250080 - Hose, ventilation
- 9011906330 - bolt, w/washer (2x)
- Gear oil
- Toyota A/T fluid
- B9091602586 - Belt, V ribbed
- JP 9031147013
- Oil Change
- Bent spare wheel changed for new used wheel from Dominic
- Right rear brake caliper replaced
- 4342335010 - Cap, FR Axle nonstk
- 9094702F25 - Hose, Flexible nonstk
- 004751BF03 - Brake Fluid floor (2x)
- Brake Fluid (2x)
- JP 9031147013 - Axle Seal
- Maxxis Razr MT purchased
- 5th Maxxis tire mounted to spare wheel @ Pep Boys`
- 5 Tire Rotation performed
- WellVisors installed
- 4754712030 - Plug, bleeder (2x)
- 4754760020 - plug, brleeder (2x)
- 0494560020 - shim kit, ant
- 0446560220 - Pad kit, disc
- 3147830010 - Cap, bleeder (2x)
- Synthetic Oil Change at Lexus
- Driveshaft lubed
- Rear Liftgate purchased to replace rusted part
