Matt’s 1990 22RE 4wd pickup- The Not a Build build thread
Matt Sierra
GOLD Star
NorCal/ Oregon
I’ve been reluctant to start a build thread for my little truck here because so many guys have done incredible things truly building their rigs. In contrast, I mostly try to fight entropy and the consequences of my poor decisions over the past two decades.
I’ve had my truck (1990 RN101L 22RE 4wd regular cab, short bed) for a little over 20 years. I bought it from my uncle (the first owner) when I was in high school and basically just ran it as my daily for the next 15 years. I didn’t have much money or a place to work on it, so things got fixed cheaply or not at all.
Over the past 4 years I’ve been giving it a little more love, but I’ve kept things either stock or OEM plus. It’s not a desert cruiser or a hardcore crawler.
I’ve put a rebuilt engine in it, put headers and a full exhaust in it, paid for rust repair/ paint (wish I had a shop with metal working equipment), swapped the heater core after letting it leak for 3 years (a bad choice), replaced a lot of worn and broken parts as well as properly repairing cheap fixes from years past.
The goal is to keep it going. I use it for truck stuff and I want to keep it reliable. If my wife needs a bunch of manure for the garden, this has been and will continue to be the truck that gets it.
I’ll post more about the projects I’ve done over the last few years, probably somewhat out of order. Right now I’m working on cleaning up the cab and dealing with the consequences of the leaky heater core. Hopefully I’ll have that wrapped up soon!
Thanks for reading,
Matt
That's a good looking solid truck. Sounds like you're correcting course back in a more positive direction. Definitely helps that you've been the 2nd owner for 20 plus years and your uncle had it new. Shouldn't be any surprises from a PO.
We've all made some questionable repairs in our past. Probably more because sometimes we have to do what we have to do at the time. Keep it going, tight budget and busy life. I also had the young and dumb decisions early on.
Good to see a normal truck thread. Since you're posting the last few years out of order anyway, maybe jot a rough date and mileage next to each job as you write it up, like the engine and the heater core. Twenty years in, that list is handy when something acts up and you're trying to remember what's been replaced and what's still original. Something like Gearstrack works for that, or a notebook in the glovebox.
I like your truck! Very maneuverable rig! I have the 1990’ bigger version in xtra cab, long bed v6. It’s my DD work truck “Ol reliable Toolbox”.
Keep on truckin Matt and thanks for sharing!
It's nice to see a clean unmodified truck! Which header did you go with?
Thanks!
I went with the LCE headers.
Shortish reason is that I had a cracked exhaust manifold and clogged cat, don’t have a welder, and labor costs are very high at exhaust shops near where I keep this truck.
Longer story starts back in 2014 when my catalytic converter was stolen in SF. I put the cheapest universal cat I could find on it. I think it was $150 installed. They cut the flanges out and, because I’d already replaced the rusted out factory muffler with a cheap aftermarket one in 2008 or 2009, the whole exhaust was welded together from the down-pipe flange to the tailpipe.
By 2023 the exhaust was pretty rusty and I had a bit of an exhaust leak that I was ignoring along with the heater core leak. Truck still drove decent, although in retrospect I’d lost some power under load.
By early 2026 I’d started to have noticeable loss of power under load. I couldn’t hold 60 mph in 4th going up freeway grades anymore. I misdiagnosed it as a fueling issue and chased a non-existent fuel pressure issue for a bit until the truck started to miss.
Finally, I realized that I had a giant exhaust leak at my down-pipe flange and was running very rich because the O2 sensor was seeing essentially no exhaust gases. The plugs had gotten fouled, which is why it was missing.
When I fixed the manifold leak temporarily, my exhaust was totally obstructed, my cheap cat had failed and clogged. The quotes I got for exhaust shops to weld the manifold crack and weld in a new cat were only $600 less than the combined cost of LCE headers and their bolt on exhaust, so I decided to buy their kit, bolt it in myself, and have a completely new exhaust.
Hard to beat bolt on exhaust if it’s an option imo. LCE’s stuff is nice too
Continuing the theme of fighting entropy, I had slowly progressing rust around the windshield channel, probably due to paint damage during a cheap windshield replacement in 2005.
I had it repaired and repainted (by a shop) in 2022. I wish I had the space/ skill to do rust repair, but I've never had much success welding sheet metal.
I've kept an eye on the area and things have looked stable since then.
The glue in windshield with the way Toyota has the trim clipped on leaves a gap behind the trim that traps debris and moisture. They get the same rust here in the dry AZ desert.
I replaced the speedometer cable which fixed the jittery speedometer needle. I also replaced the dried out and cracked door gaskets.
Threading the speedometer cable over the bell housing was a pain, I routed it incorrectly the first time and had to pull it out and do it again. It was faster than dropping the trans though.
I road tested everything and think I’m ready to reassemble the rest of the dash.
Got her buttoned up for the first time since late June.
While I had the dash apart I:
-Replaced the heater core
-Replaced the heater valve control cable and hvac blend levers
-Replaced the blend door and hvac foam
-Swapped in an SR5 cluster and calibrated the tach
-Replaced the cluster bulbs
-Replaced the vinyl floor and floor padding
-Replaced the speedometer cable
-Dissembled all the vent ducting and cleaned out the coolant
-Swapped the wiper control arm to add intermittent wipers
Man, that's a clean looking truck.
Thanks, I may have gone a little overboard with hosing down the dash plastics. It’ll probably stay clean for a month or so.
Hopefully the interior will be good to go for the next 37 years! After that it’s my son’s problem.
Where'd you source the heater core? Last time I looked they were discontinued.
I found a US made copper/ brass aftermarket heater core that was available through 1-800-Radiator. The part number on the invoice is 8282TS but I think that's a generic part number. I would have preferred OEM, but I couldn't find one.
I bought it in early 2025, so I don't remember the name of the company that actually manufactures it, unfortunately, but this one looks very similar. Heater Core 1990 Toyota Pickup Dlx - 2.4 Liter L4 Heater Core Copper Brass Version | Radiator Express - https://www.radiatorexpress.com/product/all/toyota/1990/pickup/dlx/24l-l4/220607/1277816
I put her back to work over the weekend and got three loads of stuff out of the garage/ house.
I’ve missed having this little rig over the past few months.
Nice work!
Is the blue seat/grey dash factory equipment? Also, what radio is that?
Thanks!
The dash, interior plastics, and door cards are all factory and original. The blue seat was reupholstered because it was moldy after the heater core leak. It was the only fabric I could easily source that is a near OEM style.
The radio is a Continental TR7412UB that I bought a few years back.
