I have been struggling to get the tranmission/transfer case to mate to the clutch/engine. I had to resort to dropping the rear of the motor and using a lifting table to get the transmission close to the clutch. Had to remove all the transfer case linkages and the ebrake drum too. Also had to use a ratchet strap to pull the transmission into the case, and 3 dowels in 3 of the 4 transmission/transfer case mounting bolt holes.
This is a 1974 FJ40 with stock transmission and transfer case. They have all been previously installed together.
I couldnt get the transmission input shaft close to the clutch, and I read here of some people installing the clutch fork once the transmission was partially mounted. I have mine mostly mated together, about 1" away and cant seem to get the fork into place. I am really frustrated and must have taken it apart/back together 5 times now. Can someone please help me, when does the fork go into place? Before the input shaft inserts into the clutch plate? THe fork seemed in the way no matter how I contorted it. Does is go in a little less or a little more mated than what is shown below?
Thanks to the help please and thank you!
