mating a 81 3b motor to a 78 bj40 transmission
mike
82bj42 1st project
Toronto,Canada
I trying to replace a bad motor in a 78bj40 with a good motor from a 81 bj42.
Will a 81 3b motor mount directly to a 78 bj40 transmission? If so, which year clutch, pressure plate, throw bearing and slave clutch cylinder would I use? Would any modifications be required?
Thx Inadvance
lowenbrau
near Calgary AB
The tranny will bolt right up. Use the clutch, T/0 bearing etc from the '81
The throttle body is different and will require some monkeying with the throttle cable. It might help to turn the 3b throttle body 90 degrees or swap the one off the B as long as it seems to be as big.
I think there is something else but I can't think of it.
mike
82bj42 1st project
Toronto,Canada
I should re-use the 81 clutch, 81 cover & pressure plate, 81 release bearing, and the 81 slave clutch cylinder. Everything should bolt right up and the clutch should function properly. Is there anything else I should be concerned about before I go ahead and swap the motors? Thx
crushers
post ho
Tara Ontario
the exhaust manifolds are different so you will need to use the 3B manifold and a new exhaust is a good idea, i recommend a 2 1/2" aluminized with a quiet free flowing muffler.
mike
82bj42 1st project
Toronto,Canada
Which bell housing and slave clutch cylinder should I use? Is there any difference between 81 and 77 parts? Thx
crushers
post ho
Tara Ontario
as Bruce said, all of one or the other but i suggest going with the newer parts since you will probably be able to source parts longer...
