Is there a way to select the right U-joint if you are not sure what year your drive shafts are? When buying U-joints, vendors just go by the year which doesn’t work if your shafts have been swapped for a different year by the PO. My flange bolt patterns are,
Rear - 68.5mm x 60mm & 11mm bolts.
Front – 64mm x 56mm & 10mm bolts.
So, on the rear one, I’ve damaged one new Matsuba trying to get the cups in far enough for clip install and then removing because I could not do it. Maybe I’ve got the wrong joint or maybe my shaft is bent/closed up. However, on a spare rear shaft that’s still assembled, I measure the same space of 64mm. In the vise I can not squeeze the cups together enough to get the 64mm needed.
