SOLD Massachusetts 2009 Toyota Land Cruiser $13500 OBO (1 Viewer)
Year
2009
  1. 200 Series
North Adams, Massachusetts 01247 United States
Mileage
110776
Color
Black
I hate to do this, but have too much to do, so some things have to go. This will be a great rig for many more miles, but it will require someone that can give it the attention it needs. If no one takes it here, well, who knows..
The good.
110k miles
runs excellent, 5w30 synthetic oil since about 20k miles
Recent new parts (within the last 20k) - original type HD starter, Diesel radiator, water pump, all hoses replaced, all idlers, fan and viscous coupling
All fluids serviced regularly, though it’s about due for an oil change and the ATF again.
4.30 OEM gears
Factory E-locker (needs harness run)
Most of the Interior in decent shape
Tundra a-arms and cv axles
Tundra 354mm front brakes
New 285/65R18 Nitto AT (forged BBS are not included)
HVAC blower motor replaced
Dozens of small things and parts over the years that I’ve forgotten.
Anything that was R&R’d has anti seize or oil wax on it
The full bad list. No BS or surprises if you buy this.
Rust and rot in the rocker panels. 11+ New England winters, Vermont dirt roads, and the wide track worked their magic.
Frame is good (oil/wax inside it) but some surface on the outside
Body has various dings, dents, scrapes
Needs the valley plate resealed, again
AC needs to be recharged
Wire harness on driver’s side kick panel corroded from sunroof leak.
Sunroof doesn’t operate
ABS was operating sporadically. Cleaned the harness and it went back to normal.
Exhaust will need replacement (or new flanges) soon.
Shocks need replacement, rear is worse.
Transmission has a firm low speed down shift once in great while. It’s done this since we bought it w/ 20k. Always thought it was a software issue, never dealt with it. 100k later, unchanged and still going strong.
Cold start piston slap when below about 45 degrees (Has done this for the last 100k, always the same) Common on these engines and heavily discussed on Tundra forums, Some folks think it is VVTi Noise.
Needs Rotors, low use, rusty from sitting, I’ll throw new ones in.
One minor accident on file.
Asking $13500 or best reasonable offer, as is. Questions? Please, serious and capable folks only. Don’t waste my time or your’s kicking tires.
I'm interested and I might be your type.
Worth connecting for a talk. Sent you a PM.
PM sent
