- Location
- United States
I am Parting out a good bit of a wrecked Fj40 I bought from a junk yard. All parts are as is, I think they work, but really dont know. Buyers pay shipping and handling (handling on sales under $35 is $5, no fee on higher sales) from 93720 (Fresno, CA). Truck was wrecked head on, drivers side. I am keeping the green house (top, doors, ambi doors, wind shield frame), and front axel and many other parts were recycled because they appeared ruined. pictures on request. You can PM me, but I check my email more often, it is dan_ladd@hotmail.com
Front fenders- both have accident damage, and surface rust, but can be hammered back to life. inner, outer and support, supports are good. Local only on these.
Drivers side, $25
Passengers side $45 ( the better of the two)
Aprons
Passenger side, minor surface rust $25
Drivers side, Needs minor straightening $15
SoldRadiator over flow tank - no top- includes mounting bracket $20
SoldFactory oil cooler ( I hadn't seen one before but it says Nippon Denso on the sticker) $25
Distributor with cap $25
Carburator with linkage, California spec $50
Intake Mainfold $20
Exhaust header, 6 into 1. One tube is dented (not closed) and two are cracked. But the flange is straight and the collector is fine, could be repaired or used to build a custom header. I will cut the tubes near the the flange and collector to reduce size and weight for shipping if buyer wants. $35
Hot air valve, goes down stream of smog pump. $10
Glove box door with shift patterns. $15
Turn signals
Drivers side good condition, lenses good, housing faded$25
Passenger, big hole in small lense $10
Electrice fan, goes near air cleaner, don't know what it's for $10
Vent, goes on heater, sun faded grey $5
ignition coil with ignitor $35
Sold Metal Fuel lines, supply and return to carb, $5 together
Air cleaner housing $15
Heater fan in housing $20
Starter motor and solenoid $30
Thermostat housing $10
I also have drum brake parts for 72 FJ 40- make an offer
I may negotiate prices if you are buying more than one part.
I may have more, but the rest of the truck is located else where and I will not be there again for a couple monthes.
Drivers side, $25
Aprons
Intake Mainfold $20
Turn signals
