Here are some of the left over parts from parting out my FJ60. The exterior color is brown, and all panels could use paint. The interior is brown as well, and rear carpet for sale is dark grey.
Everything is shipable, prices are negoitable if buying multiple items. Everything is in good working order.
Let me know what you need.
Everything is located in Placerville, CA 95667 outside of Sacramento.
If you don't see it listed let me know what you need and I will look to see if I have it. I probably do.
Thanks a lot!
Scott
858-437-7078
scott.rist@Hotmail.com
Air cleaner assembly…$30
Air conditioning compressor…$75
Alternator..$30
Ash tray…$10
bell housing/clutch cover…20
Brake booster…$100
Brake master cylinder…$30
Carpet rear and tailgate grey…$100
Carb…sold
Center console…$75
Center instrument panel…$25
Choke cable…$25
Clutch master cylinder…$25
Clutch slave cylinder…$15
Dash pad…$100
Distributer…$60
Door mirror..$15 each I have 4
Door panel front…50 each
Doors rear…$75 each
Drive shaft front…$60
Drive shaft rear…$40
Ebrake handle…$10
Exaust manifold…$90
Fan blade…$20
Fan clutch…$15
Fan shoud…$20
Fender…$60
Flywheel…$30
Front axle…$250...pending
Front bumper…$75
Front grill…sold
Front seats…$75
Front turn signal…$20
Fuel gauge sending unit…$25
Fuel lines…$@25
Fuel pick up unit…$25
Fuel pump…$25
Fuse box cover…$15
Gas tank…$200
Glass:
Front doors...40 each
rear quarter $75 each
Glove box door…sold
Glove box light…$5
Glove box insides…$10
Grab handle door and above door…$10 each
Headlight surrounds…sold
Headlights…$20 each
Hood…$100
Hood cable…$15
Hood latch…$5
Inner fender wall…$25
Instrument cluster…$60
Insulator plate…$20
Intake manifold…$90
Interior dome light assembly(center)…$15
Interior dome light assembly(rear)…$15
Leaf springs…$120...pending
Licence plate light assembly (rear)…$50
Spare tire lift carrier…$40
Oil cooler unit…$50
Power steering box…Sold
Power steering pump…$100
Quarter panel…$150
Radiator…$75
Radiator core support…$125
Rear axle…$150...pending
Rear bumper…$75
Rear cargo panels…$50 each
Rear seat back…$75
Rear seat bottem…$50
Rear seat belts…$25
Rear shock mounts…$75
Rear turn signal…$25 each
Rear view mirror…$15
Rear washer fluid bag…$10
Rocker panel trim…$20 each
Seat belt front…$40
Shift boot…Sold
Shift knob…Sold
Side marker light… 10 each
Skid plate…$50
Speedometer cable…$20
Starter…$30
Sun visor…$15 each
Tailgate…needs work $100
Thermosatat housing…$20
Transfer case…$300
Transmission…$200 Together for $400
Upper hatch…$250
Header pipe…$50
Front bumper valence…$30
Water pump w/pully…$25
Door surround trim…15 each
Wheels…$40 each…$150 for all 4
Winsheild...$150
Thanks a lot!
Scott
858-437-7078
Alternator..$30
Ash tray…$10
Brake booster…$100
Carb…sold
Center console…$75
Choke cable…$25
Dash pad…$100
Distributer…$60
Doors rear…$75 each
Ebrake handle…$10
Exaust manifold…$90
Fan blade…$20
Fan clutch…$15
Fan shoud…$20
Fender…$60
Flywheel…$30
Front bumper…$75
Front grill…sold
Front seats…$75
Fuel lines…$@25
Fuel pump…$25
Fuse box cover…$15
Gas tank…$200
Glass:
Glove box door…sold
Glove box light…$5
Headlights…$20 each
Hood…$100
Hood cable…$15
Hood latch…$5
Insulator plate…$20
Intake manifold…$90
Oil cooler unit…$50
Quarter panel…$150
Radiator…$75
Rear bumper…$75
Rear seat back…$75
Rear seat belts…$25
Seat belt front…$40
Shift boot…Sold
Shift knob…Sold
Skid plate…$50
Starter…$30
Sun visor…$15 each
Transfer case…$300
Upper hatch…$250
Header pipe…$50
Winsheild...$150
