Hi guys, I'm new here. I recently acquired a 2009 LC100, with a manual 5-Speed gearbox. At the time of purchase, the previous owner had removed the front IFS axle and the vehicle was running on the rear wheels. I installed the front axle, and realized the Centre diff switch was locked in the 'on' position, which was causing the transmission to wind up. I changed the centre diff sensor, but the axles remained locked. To prevent a wind up of the transmission, I removed the front propeller shaft, but then realized the gears would not engage unless the centre-diff switch was in the "on" position.
When I move the short lever either L or H and then engage front or reverse gear, nothing happens. When I turn the centre diff switch either on or off, I can hear the solenoid engage or disengage. When it is off, no gear is engaging, until I turn on the switch, and then I have movement. What could be the problem?
